Installation - Upgrade
Install Dolibarr
On a dedicated computer/server
  With DoliWamp (Windows .exe package)
- Prerequisite: Windows
This process works only for Windows users and is recommended for user with no computer knowledges. If you are experimented with Apache, PHP and Mysql installation, next chapter is better for you. However, if you are a newbie user and running Windows, you can use DoliWamp. DoliWamp is a specialized Dolibarr distribution for Windows. This distribution allows you to make an installation under Windows with all prerequisites (Apache, Mysql, PHP) and with no computer knowledge. This is steps to install DoliWamp:
  • Download last Dolibarr version for Windows DoliWamp.
For this, see page download DoliWamp on NLTechno web site.
  • Run the downloaded .exe and follow instructions.
With DoliBuntu (Ubuntu .deb package)
- Prerequisite: Linux Ubuntu
This process works only for Ubuntu or Debian Linux users and is recommended for user with no computer knowledges. If you are experimented with Apache, PHP and Mysql installation, next chapter is better for you. However, if you are a newbie user and running Ubuntu, you can use DoliBuntu. DoliBuntu is a specialized Dolibarr distribution for Ubuntu. This distribution allows you to make an installation under Ubuntu with all prerequisites (Apache, Mysql, PHP) and with no computer knowledge.
With Dolibarr (standard .tgz package)
- Prerequisite: Apache, PHP and a database server (MySQL or PostgreSQL) are already running correctly.
- Level: Users with few Web technical knowledges.
  • Check that you have installed Apache, PHP and a database server (MySQL or PostGreSQL) correctly (check list of installed packged on your server by using the package manager of your distribution). If not, install them (use last recent version).
Note: The installer can create optionnaly the database if it does not exists yet, but in this case, you must know your database admin user and password.
For Linux users, if you have just installed MySQL database, the admin user is root. You must run the following command to initialize its password:
mysql
Then enter and \q to quit.
To check that connexion with the new couple user/password works, launch the command
mysql -u root -p
And type your password newrootpass then \q to quit if connexion has been successfull.
For Linux users, if you have just installed PostgresSQL, you must run the following command to initialize an admin user and password. For this, add the following line in file /etc/postgresql/x.x/main/pg_hba.conf (replace x.x with your postgres version)
sudo -s -u postgres
createuser dolibarrowner
psql -d template1 -c "alter user dolibarrowner with password dolibarrownerpass"
exit
sudo /etc/init.d/postgresql-x.x restart
  • Go into the directory where to install Dolibarr (the web root directory defined for your web server)
  1. For Debian and Ubuntu families, it is generally: /var/www
  2. For Mandriva: /var/www/html
  3. For RedHat: to complete
  4. For Suse: to complete
$ cd /var/www
  • Get the application archive of last stable version
  • Uncompress archive
$ tar xvfz dolibarr.tgz
  • Rename directory dolibarr-x.y.z into dolibarr to have a directory name that does not depends on version (replace x.y.z with source version)
$ mv dolibarr-x.y.z dolibarr
  • As a root user, change permission to be sure to have read only files for groups and others
  • As a root user, create, into directory dolibarr/htdocs/conf, an empty configuration file called conf.php and set, as owner, the web server user (example www-data on Debian, nobody on old RedHat, apache on Mandriva, recent RedHat or other distributions ...). This is required because the web server will have to write into this file during install process.
  • Always as a root user, create a directory that will serve to save all generated and stocked by Dolibarr (PDf invoices, uploaded images, ...), and attribute to this directory a owner that must be the web server (example www-data on Debian, nobody on old RedHat, apache on Mandriva or recent RedHat, ...). The web server must have write permission into this directory.
  • Now call your browser to point to the main page
  • Follow instructions of setup steps until end of install process.
  • For security reason, we recommend, once setup is finished, to create a file install.lock into Dolibarr installed directory that only root user can delete. This will lock the call of the install process again (you will have to remove it for upgrades).
If this is not done, Dolibarr will show you a warning one logged by an administrator user.
On a mutualized Web Hosting Provider
It is not possible to provide a generic documentation to install Dolibarr on a particular Web hosting provider as this depends on provider. In most cases, using the process to install Dolibarr from the "standard .tgz" file (see previous chapter) should works.
Upgrade Dolibarr
With DoliWamp (.exe package)
  • Download new .exe package of DoliWamp.
  • Run downloaded .exe file and follow steps without changing any default values. This will upgrades all your files.
  • At the end of the execution, your browser is launched with a page to ask you to run upgrade of your database. Choose the upgrade according to your case.
If there is more than one version late, you must restart this setup a second time to choose launch all migration steps to be in new version from your old version.
With DoliBuntu (.deb Ubuntu package)
Process to upgrade using Debian/Ubuntu package is same than install process, so it is as easy as installation a package. You can also read page Dolibarr for Ubuntu.
With Dolibarr (.tgz package)
This chapter describes an upgrade process of Dolibarr (from an old existing version) to a more recent one. It works for any Dolibarr version that is >= 2.0.0
  • Go into the directory where you installed Dolibarr (it might be the root directory of your web, for example /var/www under Debian)
$ cd /var/www
  • Get archive of last version
  • Uncompress the archive
  • Copy all new extracted files (the one uncompressed into directory dolibarr-x.y.z) to the directory where you put your old Dolibarr version. This will overwrite old files with new ones without removing files specifics to your installation (like conf.php file or complementary non official installed modules).
  • If no error, you can now remove the directory of source files
$ rm -fr dolibarr-x.y.z
  • Now call the install/ page of Dolibarr in your browser
If you have a message that tell the install process is locked by a file, remove the file install.lock stored in Dolibarr root directory.
  • Choose Update in proposed menu
If this is not done, Dolibarr will show you a warning once logged with an administrator user.
$ echo > dolibarr/install.lock
$ chmod 444 dolibarr/install.lock
Setup a LDAP connexion
To complete.
Import external data
See page Setup.
