Subscription amount Dolibarr Foundation
You will find here minimum amount for subscriptions to the Dolibarr foundation, depending on your status.
Physical persons
This is when you subscribe for yourself.
Minimum amount of subscription for physical persons is: 10 € minimum.
Moral persons
If your subscription is for your company, foundation, university, the amount depends on characteristics of this company, foundation or university.
Companies
Subscription amount depends on you turnover :
- CA lower than 100 000 € : subscription is 50 €
- CA from 100 000 to 200 000 € : subscription is 100 €
- CA from 200 000 to 500 000 € : subscription is 200 €
- CA from 500 000 to 1,5 millions € : subscription is 500 €
- CA from 1,5 to 3 millions € : subscription is 750 €
- CA from 3 to 5 millions € : subscription is 1 500 €
- CA higher than 5 millions € : subscription is 2 500 €
Foundations
For foundations, subscription depends on your budget :
- Budget lower than 10 000 € : subscription is 10 €
- Budget from 10 000 € to 100 000 € : subscription is 100 €
- Budget from 100 000 € to 300 000 € : subscription is 250 €
- Budget from 300 000 € to 500 000 € : subscription is 500 €
- Budget from 500 000 € to 3 millions € : subscription is 750 €
- Budget from 3 millions € to 5 millions € : subscription is 1 500 €
- Budget higher than 5 millions € : subscription is 2500 €
Other
Towns
- Less than 2 500 people : subscription is 100 €
- From 2 500 to 5 000 people : subscription is 250 €
- From 5 000 to 10 000 people : subscription is 500 €
- From 10 000 to 20 000 people : subscription is 700 €
- From 20 000 to 30 000 people : subscription is 850 €
- From 30 000 to 50 000 people : subscription is 1 000 €
- From 50 000 to 80 000 people : subscription is 1 250 €
- From 80 000 to 100 000 people : subscription is 1 500 €
- More then 100 000 people : subscription is 2 500 €
Education
- Department of university, : subscription is 200 €
- University: subscription is 1000 €
