Module MemCached
Module name | |
Editor / Editeur | NLTechno - http://www.nltechno.com/ |
Prerequisites / Prérequis |
Dolibarr min version: 2.9.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2010-05-24 |
Note / Nota |
Allows Dolibarr to increase speed by using a cache server MemCached. According to platform, speed increase can be between 15% (Linux) and 40% (Windows). Difference of gain exists because Linux is already optimized for PHP.
Module setup page:
In the module setup page, you must fille the following informations:
- Name of Memcached server: Put a DNS name or IP address of Memcached server.
- Port or Memcached server: Put here the port of the Memcached server.
Save and that's all. Dolibarr should now use the cache server when it can.
This module is a technical module. As soon as setup is done, Dolibarr use the cache server when it thinks it's necessary. There is no other things to do.
CVS Repository
