Module MemCached
Module name
Editor / Editeur NLTechno - http://www.nltechno.com/
Dolibarr min version: 2.9.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2010-05-21
Allows Dolibarr to increase speed by using a cache server MemCached. Note that it must be a MemCached server and does not work with a MemCache server (Two differents products). According to platform, speed increase can be between 15% à 40%.
Module setup page:
In the module setup page, you must fille the following informations:
  • Name of Memcached server: Put a DNS name or IP address of Memcached server.
  • Port or Memcached server: Put here the port of the Memcached server.
Save and that's all. Dolibarr should now use the cache server when it can.
This module is a technical module. As soon as setup is done, Dolibarr use the cache server when it thinks it's necessary. There is no other things to do.
CVS Repository
