Interfaces Dolibarr toward foreign systems
Dolibarr provides a simple mecanism to make Dolibarr act into an external system on a Dolibarr event (For more inforation on the other direction and allow an external system to act into Dolibarr system, see page Interfaces from foreign systems toward Dolibarr).
Execute your own code on a Dolibarr event
To execute personalized code after a Dolibarr event (create/modify/remove a third party/invoice/product or other), Dolibarr offers a mechanism of business triggers. This mechanism allows you to personalize a work-flow to have Dolibarr business events being synchronized into another application for example. You can also use triggers to modify the behavior of Dolibarr itself: for example, to create automatically a contract when an invoice is validated.
1) Copy file htdocs/includes/triggers/interface_all_Demo.class.php under the new name:
  • interface_all_Xxx.class.php
or
  • interface_modMyModule_Xxx.class.php
where Xxx is a string of your choice startint with uppercase character and MyModule is the name of a module if you want that trigger is activated only if module MyModyle is activated. If you want the trigger to be always active, use all instead of modMyModule. This new file must be saved inside same directory. Note: Value you can use for modMyModule are values found in directory htdocs/includes/modules.
For example, you can name your new trigger file: htdocs/includes/triggers/interface_modFacture_Myworkflow.class.php
2) Edit the file interface_modMyModule_Myworkflow.class.php to rename class InterfaceDemo by InterfaceMyworkflow
Then go on page Home-> System Infos -> Dolibarr -> Triggers. Your new trigger file must appears in the list without any error message. This means preceding actions have been done successfully.
3) Return now to edition of file to add your own code inside function run_trigger. This function is called at each Dolibarr business event. Put your code according to events on which you want to run. Each event is identified by a code (see following chapter to get full list of codes). So you can react or no after an event by doing just a test on variable $action:
You can also use in this function the preinitialized following variables:
  • $object is the object on which action is done (see next chapter)
  • $user is the object containing all information of Dolibarr user that realizes the business event.
  • $langs is the object that contains the user language and translations strings
  • $conf is the object that contains all the Dolibarr configuration.
4) Once your trigger file has been developed, last action is to test by using Dolibarr to execute the business event that should trigger your code. Warning, call of function run_trigger is encapsulated into a transaction. If your code return a KO code, the calling function may rollback the transaction (this depends on calling function). Add log information inside your function run_trigger to know if your code is correctly triggered and runs correctly. For this, you can use the function dol_syslog("my log message", LOG_DEBUG);
List of known events
Dolibarr events that launch triggers are identified by an event code $action. Existing codes are:
  • USER_CREATE
  • USER_MODIFY
  • USER_DISABLE
In such cases, the variable $object contains an object of type user.class.php
  • COMPANY_CREATE
  • COMPANY_MODIFY
  • COMPANY_DELETE
In such cases, the variable $object contains an object of type societe.class.php
  • PRODUCT_CREATE
  • PRODUCT_MODIFY
  • PRODUCT_DELETE
In such cases, the variable $object contains an object of type product.class.php
  • ORDER_CREATE
  • ORDER_VALIDATE
  • ORDER_DELETE
In such cases, the variable $object contains an object of type commande.class.php
  • ORDER_SUPPLIER_CREATE
  • ORDER_SUPPLIER_VALIDATE
In such cases, the variable $object contains an object of type fournisseur.commande.class.php
  • PROPAL_CREATE
  • PROPAL_MODIFY
  • PROPAL_VALIDATE
  • PROPAL_CLOSE_SIGNED
  • PROPAL_CLOSE_REFUSED
  • CONTRACT_CREATE
  • CONTRACT_MODIFY
  • CONTRACT_ACTIVATE
  • CONTRACT_CANCEL
  • CONTRACT_CLOSE
  • CONTRACT_DELETE
In such cases, the variable $object contains an object of type contract.class.php
  • BILL_CREATE
  • BILL_MODIFY
  • BILL_VALIDATE
  • BILL_CANCEL
  • BILL_DELETE
In such cases, the variable $object contains an object of type facture.class.php
  • PAYMENT_CUSTOMER_CREATE
In such cases, the variable $object contains an object of type paiement.class.php
  • PAYMENT_SUPPLIER_CREATE
In such cases, the variable $object contains an object of type paiementfourn.class.php
  • FICHEINTER_VALIDATE
In such cases, the variable $object contains an object of type ficheinter.class.php
  • MEMBER_CREATE
  • MEMBER_VALIDATE
  • MEMBER_SUBSCRIPTION
  • MEMBER_MODIFY
  • MEMBER_RESILIATE
  • MEMBER_DELETE
In such cases, the variable $object contains an object of type adherent.class.php
  • CATEGORY_CREATE
  • CATEGORY_MODIFY
  • CATEGORY_DELETE
In such cases, the variable $object contains an object of type category.class.php
  • SHIPPING_VALIDATE
  • SHIPPING_MODIFY
In such cases, the variable $object contains an object of type expedition.class.php
Manage new events
To manage other events on objects than the one defined before, you mist edit the Dolibarr code to add the following code inside the business method of the class file of the object:
// Call triggers
$result=$interface->run_triggers('SHIPPING_MODIFY',$this,$user,$langs,$conf);
// End call triggers
Here, $this contains the business class with all information to send to the trigger functions. Replace 'XXXXX_YYYYYY' by an event code not already used. Then you will be able to add inside the run_trigger method, a "if" to manage this code. The run_trigger method will contains a part of code like this :
      <b>
      if ($action == 'XXXXX_YYYYY')
      </b>
Conclusion
