FAQ Having long product list
Revision as of 13:52, 29 April 2010 by Eldy (talk | contribs) (Created page with 'Category:FAQ EN '''When I create invoices, orders, contracts, etc, how can i find my product when i have thousands of products ? ''' You can * activate the Ajax search (as ...')
You can
  • activate the Ajax search (as admin user go on menu Home - Setup - Display: check that parameter "Disable Javascript/Ajax" is to off).
  • Choose option: "Use a form search to find product (instead of a long combo list)" into module parameter Products (menu Home - Setup - Modules: search module "Products" and click on icon to setup module on the right of module line).
