Table llx deplacement
Revision as of 11:14, 5 April 2010 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
En verysmall.png Contains the expenses and trips notes
Fr verysmall.png Contient les notes de frais et déplacements
Es verysmall.png Contiene las notas de gastos y desplazamientos
Structure
Table
Version 1.4 2010/03/21
rowid int(11) NO PRI auto_increment technical index
ref varchar(30) NULL reference donation (TODO change to NOT NULL)
entity int(11) NO 1 multi company id
date_c datetime NO date of creation
tms timestamp NO CURRENT_TIMESTAMP last update date
dated datetime YES NULL date of trip
fk_user int(11) NO ID of user made the trip note (llx_user->rowid)
fk_user_author int(11) YES NULL ID of creator user of trip note (llx_user->rowid)
type varchar(12) NO type of trip note
fk_statut integer YES NULL Status of trips/expenses (0=Draft, 1=Validated)
km real YES NULL amount or km
fk_soc int(11) YES NULL ID society affected (llx_societe->rowid)
fk_projet int(11) YES NULL ID proyect affected (llx_projet->rowid)
note text YES NULL notes
note_public text YES NULL public notes
Keys
Version 1.1 2009/10/07
Key Type Fields
PRIMARY PRIMARY rowid
