Interfaces Dolibarr toward foreign systems
Dolibarr provides a simple mecanism to make Dolibarr act into an external system on a Dolibarr event (For more inforation on the other direction and allow an external system to act into Dolibarr system, see page Interfaces from foreign systems toward Dolibarr).
Execute your own code on a Dolibarr event
  Page waiting for translation. To translate, create an account, go back and clic on "Modify".
  Page en attente de traduction. Pour traduire, créez un compte, revenez et cliquez sur "Modifier".
  Página a traducir. Para traducirla, cree una cuenta, vuelva a la página y haga clic en "editar".
  Pagina da tradurre. Per tradurla, crea un utente, torna indietro e clicca su "modifica".
  Página a aguardar por tradução. Para traduzir, crie uma conta, volte atrás e clique em "Modificar".
  Seite wartet auf Übersetzung. Um Übersetzung zu erstellen, richte einen Account ein, geh zurück und klicke auf "bearbeiten".
  页面等待翻译。若要翻译本页,先创建一个帐户、登录并返回本页后单击“编辑”。
To execute personalized code after a Dolibarr event (create/modify/remove a third party/invoice/product or other), Dolibarr offers a mecanism of business triggers. This mecanism allows you to personalize a workflow to have Dolibarr business events being synchronized into another application for example. You can also use triggers to modify the behaviour of Dolibarr itself: for example, to create automatically a contract when an invoice is validated.
1) Copy file htdocs/includes/triggers/interface_all_Demo.class.php under the new name:
  • interface_all_Xxx.class.php
or
  • interface_modMyModule_Xxx.class.php
where Xxx is a string of your choice startint with uppercase character and MyModule is the name of a module if you want that trigger is activated only if module MyModyle is activated. If you want the trigger to be always active, use all instead of modMyModule. This new file must be saved inside same directory. Note: Value you can use for modMyModule are values found in directory htdocs/includes/modules.
For example, you can name your new trigger file: htdocs/includes/triggers/interface_modFacture_Myworkflow.class.php
2) Edit the file interface_modMyModule_Myworkflow.class.php to rename class InterfaceDemo by InterfaceMyworkflow
Then go on page Home-> System Infos -> Dolibarr -> Triggers. Your new trigger file must appears in the list without any error message. This means preceding actions have been done successfully.
3) Return now to edition of file to add your own code inside function run_trigger. This function is called at each Dolibarr business event. Put your code according to events on which you want to run. Each event is identified by a code (see following chapter to get full list of codes). So you can react or no after an event by doing just a test on variable $action:
You can also use in this function the preinitialized following variables:
  • $object is the object on which action is done (see next chapter)
  • $user is the object containg all information of Dolibarr user that realizes the business event.
  • $langs is the object that contains the user language and translations strings
  • $conf is the object that contains all the Dolibarr configuration.
4) Une fois le code réalisé, il n'y a plus qu'à tester, en provoquant l'évènement déclencheur dans Dolibarr. Attention, l'appel au run_trigger et encapsuler dans un transaction. Si votre trigger renvoie un code ko, la fonction appelante peut annuler la transaction (ceci dépend de la fonction appelante). Ajouter des traces dans un fichier dans la fonction run_trigger afin de vous assurer que le code s'exécute bien. Vous pouvez pour cela si vous le désirer, utiliser la fonction dol_syslog("mon texte de trace", LOG_DEBUG);
List of known events
Dolibarr events that launch triggers are identified by an event code $action. Existing codes are:
  • USER_CREATE
  • USER_MODIFY
  • USER_DISABLE
In such cases, the variable $object contains an object of type user.class.php
  • COMPANY_CREATE
  • COMPANY_MODIFY
  • COMPANY_DELETE
In such cases, the variable $object contains an object of type societe.class.php
  • PRODUCT_CREATE
  • PRODUCT_MODIFY
  • PRODUCT_DELETE
In such cases, the variable $object contains an object of type product.class.php
  • ORDER_CREATE
  • ORDER_VALIDATE
  • ORDER_DELETE
In such cases, the variable $object contains an object of type commande.class.php
  • ORDER_SUPPLIER_CREATE
  • ORDER_SUPPLIER_VALIDATE
In such cases, the variable $object contains an object of type fournisseur.commande.class.php
  • PROPAL_CREATE
  • PROPAL_MODIFY
  • PROPAL_VALIDATE
  • PROPAL_CLOSE_SIGNED
  • PROPAL_CLOSE_REFUSED
  • CONTRACT_CREATE
  • CONTRACT_MODIFY
  • CONTRACT_ACTIVATE
  • CONTRACT_CANCEL
  • CONTRACT_CLOSE
  • CONTRACT_DELETE
In such cases, the variable $object contains an object of type contract.class.php
  • BILL_CREATE
  • BILL_MODIFY
  • BILL_VALIDATE
  • BILL_CANCEL
  • BILL_DELETE
In such cases, the variable $object contains an object of type facture.class.php
  • PAYMENT_CUSTOMER_CREATE
In such cases, the variable $object contains an object of type paiement.class.php
  • PAYMENT_SUPPLIER_CREATE
In such cases, the variable $object contains an object of type paiementfourn.class.php
  • FICHEINTER_VALIDATE
In such cases, the variable $object contains an object of type ficheinter.class.php
  • MEMBER_CREATE
  • MEMBER_VALIDATE
  • MEMBER_SUBSCRIPTION
  • MEMBER_MODIFY
  • MEMBER_RESILIATE
  • MEMBER_DELETE
In such cases, the variable $object contains an object of type adherent.class.php
  • CATEGORY_CREATE
  • CATEGORY_MODIFY
  • CATEGORY_DELETE
In such cases, the variable $object contains an object of type category.class.php
Manage new events
// Appel des triggers
// Fin appel triggers
Ici, $this doit être l'objet de la classe métier qui contient toutes les informations à passer au trigger. Remplacer, de plus, le 'XXXXX_YYYYYY' par un code évènement non déjà utilisé. Il sera alors possible d'ajouter dans la méthode run_trigger, un if qui permet de gérer ce code. La méthode run_trigger serait alors de la forme :
      <b>
      if ($action == 'XXXXX_YYYYY')
      </b>
Conclusion
Vous pouvez donc en quelques minutes, ajouter une interface Dolibarr vers exterieur sans risque puisqu'on ne touche pas au code Dolibarr, on s'est contenté de placer un nouveau fichier trigger dans le répertoire des triggers. Si cette interface peut être utile à d'autre, n'hésitez pas à la packager en tgz (voir les wiki sur la diffusion de modules) et de la soumettre dans l'espace des téléchargement-contributions sur le site de Dolibarr.
