Revision as of 18:56, 30 March 2010 by Eldy (talk | contribs) (→‎SQL rules)
Versions
  • Dolibarr must works on:
  2. PHP 4.3 or + (Must works with no need of complementary PHP module, except module to PHP module to access database).
  3. Mysql 3.1 or +
PHP Norms
  • Dolibarr is written with PHP and supports all PHP version higher than 4.1. All files must end with extension .php
  • Usage of superglobals PHP variables must use dedicated operators $_GET, $_POST, $_COOKIES, $_SERVER, $_ENV.
Other operators ($HTTP_SERVER_GET, ...) are now deprecated inside PHP, so they must no more be used. Like that code will works alos if option register_long_arrays is to off. Moreover, the code must works when PHP option register_globals is off (recommanded by PHP). It must works the same way that when option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"].
  • When several variables must be initialized with same value, you must use several lines
$var1=1;$var2=1;$var3=1;
instead of
$var1=$var2=$var3=1;
that is slower.
  • String must be rounded by simple quote and vairable inside string must be out of the quote.
  • Comments must use the C syntax, ie a double antislash for a comment on one line and a slash-star to open a bloc for several lines
/* Bloc of comment
 * End of bloc
for ($i = 1 , $i < 2 ; $i++)
  // comment on one line
  print $i;
  • Files must be saved with Unix format (LF) and not Windows (CR/LF). Unif format is compatible on all OS like Unix like, Windows, Mac, but the Windows text file format is no working on some PHP under Unix.
Functions must return a value strictly higher than 0 if successfull and strictly lower than 0 if error.
SQL rules
  • All SELECT * are forbidden ! Any SELECT must define complete list of fields to get. This avoid confusion. Example:
  • Dans les requêtes SQL, on quote les champs mais pas les numériques qui contiennent des montants destinés à être stockés dans des champs de type double ou real. Les quotes sur les numériques de type float provoquent parfois un stockage d'une valeur différente. Par exemple 412.62 dans le insert sera en fait stocké avec la valeur 412.61999512 en base si le champ est de type double(24,8). Et seul le PHP voit 412.61999512. Les autres outils verront 412.62 donnant l'impression qu'il n'y a pas de problème. Et c'est le PHP qui a raison, il y a problème en base. En supprimant les quotes sur les numériques, cela va mieux.
Example:
Remarque, le pb des float est général et pas seulement sur les accès base, il est présent dans tous les languages quand on travaille sur des nombres réels, aussi ils doivent être, dès que affectés, nettoyés par la fonction price2num avec le 2eme paramètre renseigné à: 'MU', 'MT' ou 'MS' selon le besoin. (voir doc fonction)
Dans la pratique, afin d'etre compatible avec toutes les précisions des pays, on utilisera les types suivants:
- double(24,8) pour tout montant
- double(6,3) pour les taux de tva
- real pour une quantité
  • Dolibarr doit fonctionner même avec l'option strict de Mysql active.
Pour l'activer, ajouter la ligne suivante dans le fichier config du serveur Mysql (my.cnf)
sql-mode="STRICT_ALL_TABLES"
  • Les fonctions NOW ou SYSDATE sont interdites au sein des ordres SQL. S'il faut saisir la date du moment dans un champ, la valeur doit venir du PHP et non du moteur de base de données. Ceci afin d'avoir une meilleure portabilité du code mais surtout d'avoir une gestion correcte des TimeZone.
Normes HTML
  • Tous les attributs dans les balises HTML doivent être *en minuscule* et quotés avec des *doubles quote* (Norme xhtml)
  • Les liens href doivent être absolus et se baser pour les pages sur la constante DOL_URL_ROOT qui pointe sur htdocs et pour les images se base sur l'appel de la fonction img_picto.
Par exemple:
print '<a href="'.DOL_URL_ROOT.'/monrep/mapage.php">'.img_picto('Texte alt','nompictopng','').'</a>';
  • Le javascript et l'appel aux scripts java dans les pages php est à proscrire. Si toutefois du code javascript est inclus, il doit être conditionné par le test sur "$conf->use_javascript"
if ($conf->use_javascript)
...  // Le code php qui génère du javascript est ici
  • Les popups windows ne doivent pas être utilisées, sauf pour des tooltips (et restent condtionnées par le point ci-dessus).
  • Les scripts externes sont écrits en Perl s'ils ne peuvent l'être en php, l'utilisation d'un autre langage n'est pas interdit mais doit être discuté au préalable dans la mailing list des développeurs. Le langage devra être maitrisé par au moins 2 développeurs pour en assurer la maintenance.
Squelettes de code
Afin d'uniformiser le code et d'accélérer le développement de nouveaux composants dans Dolibarr, se trouvent dans le répertoire dev/skeletons, 4 squelettes de code tout préparés.
  • 1 qui sert d'exemple de descripteur de module: myModule.class.php
  • 1 qui sert d'exemple de code pour faire une nouvelle classe: skeleton_class.class.php
  • 1 qui sert d'exemple de code pour faire une nouvelle page: skeleton_page.php
  • 1 qui sert d'exemple de code pour faire un script à exécuter en ligne de commande: skeleton_script.php
Servez-vous en comme exemple. Notons que ces squelettes sont aussi utilisés par le générateur de code PHP qui est décrit dans la chapitre de développement de module Dolibarr pour accélérer vos développement.
Les dates et TimeZone
Dolibarr se veut une application mutli-utilisateur et multi-localisation. Il convient donc de stocker les dates dans le bon format. Pour éviter les problèmes de conversion, les règles suivantes doivent être appliquées:
  • Une date en mémoire doit être au format Timestamp GMT.
  • Une date stockée en base de données contient le Timestamp GMT en rapport avec la date soumise dans la requête en heure locale du serveur PHP. Cela ne concerne pas les dates mises à jour automatiquement par la base (champ tms en base).
Ainsi le 1er janvier 1970, 3 heures à Paris (TZ=+1) = 2 heures à Greenwitch (TZ=0) sera stocké en mémoire 7200 et sera soumis à la base de données avec la chaine '19700101030000' (PHP convertit en heure de son TZ et la base déconvertit avec son TZ qui est le même que celui de PHP).
Les méthodes select doivent donc traduire les champs dates lus qui sont au format chaine TZ de la base ('19700101030000') par appel de la méthode db->jdate afin de récupérer une information en mémoire au format Timestamp GMT. Et les méthodes insert doivent lors de la génération de la requête convertir la date mémoire connue en variable, par la méthode db->idate (Voir exemples générés par le squelette).
  • Les dates mises à jour automatiquement par la base (champ tms en base) contiennent le Timestamp GMT au moment où la modification est faite. Les méthodes select récupèrent directement cette donnée en mémoire au format Timestamp GMT.
L'encodage UTF8/ISO
  • En base de donnée, les données sont en UTF8 ou ISO. Cela dépend du pagecode de la base, donc des options à la création de cette base. Dans tous les cas le driver d'accès base Dolibarr (dans /lib/database) s'arrange à la lecture et insertion pour convertir vers et depuis de l'UTF8.
  • Les données en mémoires sont donc stockées en UTF8 (instances d'objets PHP).
  • Les pages web affichées à l'écran sont au format UTF8 (avec les versions < 2.5.1, c'est le vieux paramètre $character_set du fichier conf.php qui définissait le format de sortie).
Les nombres réels, montants et calculs
print 239.2 - 229.3 - 9.9;
Vous n'obtiendrez pas zéro mais un nombre très petit en puissance de 10 négative. Si vous obtenez zéro, vous pourrez trouvez d'autres exemples qui ne fonctionnent pas. Le problème des float est général, une variable résultante de calcul de nombre réels doit SYSTEMATIQUEMENT être nettoyée par la fonction price2num avec le 2eme paramètre renseigné à: 'MU', 'MT' ou 'MS' selon le besoin (voir doc fonction).
Création de tables
Ne pas créer de table à l'utilisation, c'est-à-dire à la première utilisation du module. Si vous créez un module qui utilise des tables qui ne sont pas intégrées en standard dans le code de Dolibarr, veillez à suivre le didacticiel Créer un module qui explique comment joindre des tables qui se créent à l'activation du module et non à son utilisation (voir plus haut).
Logs
Ajouter des traces dans votre code avec la fonction dolibarr_syslog($yourmessage, LOG_INFO|LOG_DEBUG|LOG_WARNING|LOG_ERR);
Répertoires de travail
Si vous avez besoin de créer un répertoire de travail, dans votre code, faites référence à ce répertoire par DOL_DATA_ROOT.'/monmodule'. Le répertoire peut être créé dans votre code à l'exécution par le code suivant:
if (! is_dir($mymoduledir)) create_exdir($mymoduledir);
Patterns of code organization
Martin Fowler has identified 3 way to organize:
  • The Domain Model
  • The Table Module
Has shown in code skeletons (see previous chapter), Dolibarr use concept of Table Module.
  • Le Table And Row Data Gateway
C'est le plus simple. On crée une table par classe et chaque classe est un pont avec la table correspondante, voir une classe par ligne de table. Une instance de classe étant alors un enregistrement de la table. La classe ne contient que du code d'accès aux lignes ou colonnes de tables.
  • Le Active Record
Identique au précédent, mais on se permet d'ajouter quelques fonctions métiers sur la classe, à conditions que ces fonctions soient propres à la table ou à l'enregistrement.
Exemple: C'est le mode choisi pour les développements Dolibarr et de nombreuses autres applications PHP qui ont leur propre framework et pratiques de développements.
  • Le Data Mapper
Les classes représentent les entités du problème et non les données. Il faut donc doubler, tripler... ces classes avec des classes Mapper pour accéder aux données. Plus "puriste" sur le papier car plus proche du métier, ce mode a aussi l'inconvénient d'être plus complexe sur le plan pratique. Exemple: C'est le choix si on utilise le Framework d'ORM Propel (http://propel.phpdb.org/trac/). On le trouve donc sur des applications plus lourdes basées sur cet ORM entre autres.
Pour les développements Dolibarr, il est recommandé d'utiliser le mode de liaison Active Record qui offre les avantages d'un modèle proche du métier sans en avoir la complexité et sans trop masquer non plus la technique. C'est dans ce mode que le développement, la compréhension du code et la maintenance technique et/ou fonctionnelle semble la plus productive (ceci est toutefois un éternel débat entre les puristes et les pragmatiques, débat dans lequel personne ne peut vraiment avoir raison, car tout dépend des objectifs à atteindre).
