The Dolibarr configuration file is conf/conf.php. It is created by the automatic install process.
Content
Content of this file is :
$dolibarr_main_document_root="/home/www/dolibarr/htdocs";
$dolibarr_main_url_root="http://mydomain.com/dolibarr";
$dolibarr_main_db_type="mysql";
$dolibarr_main_db_host="localhost";
$dolibarr_main_db_port="3306";
$dolibarr_main_db_name="dolibarr";
$dolibarr_main_db_user="dolibarr";
$dolibarr_main_db_pass="";
Other options:
$dolibarr_main_demo="demologin,demopass"
-> Disable some features to limit software when used as a demo software. This is to avoid that everybody make everything with a demo instance of Dolibarr.
$dolibarr_main_prod="1"
-> When this option is added in conf file, no information will be reported by Dolibarr when an internal error occurs. This is to use in a production environment to hide any information to hackers.
$dolibarr_main_authentication="dolibarr"
-> Allows to change the way the password is checked when a user ty to login to Dolibarr:
- Value "dolibarr" means check is done with the password stored in database.
- "ldap" ask to use a LDAP server (in this case, you must also define other LDAP parameters (See file conf.php.example)
- "http" use basic http protocol (need to configure your web server to set dolibarr inside a basic authentication area)
Dolibarr provide a model of file named conf/conf.php.example where each parameter is commented.
Read/Write file
This file must never be modified, never read directly by any Dolibarr feature.
It is created by the install or update process of Dolibarr (install/index.php) that is the only process allowed to make actions on this file.
Usage in coding
Content of file must be used by developers by using predefined constants or the object $conf created by the script master.inc.php that must be called at beginning of every PHP program (scripts or pages).
So:
- $dolibarr_main_document_root is known in code in constant: DOL_DOCUMENT_ROOT
- $dolibarr_main_url_root is known in code in constant: DOL_URL_ROOT
- $dolibarr_main_db_type is known in code on variable $conf->db->type
- $dolibarr_main_db_host is known in code on variable $conf->db->host
- $dolibarr_main_db_port is known in code on variable $conf->db->port
- $dolibarr_main_db_name is known in code on variable $conf->db->name
- $dolibarr_main_db_user is known in code on variable $conf->db->login
- $dolibarr_main_db_pass is not known by code. It is read by script master.inc.php (called by every PHP program) that created on object connexion $db then variable $dolibarr_main_db_pass is erased.
You development should only need to use constants DOL_DOCUMENT_ROOT (that indicate physical path of directory where permanent or temporary files are stored) and DOL_URL_ROOT (that indicate relative URL that is Dolibarr root).
More information and initialized objects are available after including a call to main.inc.php in your PHP pages.
See tutorial on page Module development or Script development for more information.
