Module NumberWords
| Module name | |
| Editor / Editeur | NLTechno - http://www.nltechno.com/ |
Dolibarr min version: 2.6.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2010-02-12 |
| Note / Nota |
With this module, Dolibarr is able to translate decimal number or amount into full text strings ("110 dollars" will give "one hundred and ten dollars")
From the application
Manually
unzip modulefile.zip
Then see "Usage"
- If you are an end user: add the string __TOTAL_TTC_WORDS__, __TOTAL_HT_WORDS__, __TOTAL_VAT_WORDS__ in any "free text for PDF" area in setup of invoices, orders, proposals... This string will be replaced with the amount with tax, without tax or for vat in full clear alphabetic text.
- If you are a developper: You can also use, anywhere in the code, the method
$langs->getLabelFromNumber($mynumber,0|1)
to get full text string of a number or amount.
Development of this module is not included inside standard CVS repository of Dolibarr but into the complementary modules area. So source code is hosted into following CVS repository:
- CVS Repository: :ext:savannahlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr
- CVS Module: dolibarrmod
To have a view on changes done on this repository, see page http://www.nltechno.com/stats/dolibarr/cvschangelogbuilder_dolibarrmod.html
