Module Projects
| Project | |
| Numero/ID of module | 400 |
The Project module allows you to manage tasks and time consuming on tasks. You can also link Dolibarr entities to a project (like commercial proposals, des customers orders or customers invoices).
Definitions
Before starting to use the Project module, it is important to understand the difference and meanings of following terms Events / Tasks / Journals. This terms are often misunderstood and they are used differently. So you should first know the real definitions of this terms as they are used by most ERP/CRM softwares. For this, you can read definitions on page Events-Todo-Journal
The project module is designed to manage Tasks.
Create a project
A project can be public or private. Public projects (and all tasks) can be read/edited by anybody with read project permissions. Private project (and all tasks) can be read/edited only by users defined as contact/actors of project + the creator of project (if all contacts are removed, we must keep at least one user authorized on project. This is the creator).
Create a task
- A task can be created only on a shared project (with no responsible) or on a project you are responsible.
- A task is on the root of the project or under another task of the project.
Remove a project
Remove a task
Examples of use cases
| UCMP01: | |
| Situation | |
| Actions | |
