Roadmap and Release 2.2.0 ("Purged version")
Roadmap Dolibarr pour la version 2.2.0
  • Corrections des retours de la 2.1.0
  • Correction pb avoir client
- Add more statistics on main page. - Add option to add message on login page. - Management of categories for third parties. - Add volume on products properties. - Support for LDAP authentication. - Full member synchronisation with LDAP database in fundation module. - More LDAP fields supported for user synchronization. - Better logger for install. - First changes to support UTF8. - Add a "forget password" feature. - Setup process can run several migrate files if need to jump several versions to upgrade. - Support for webcalendar 1.1 in webcalendar module. - Support for menu in database. - Better support for using Dolibarr on more WHP. - Removed some deprecated files and clean code. - New theme: Auguria - Removed PHP warnings. - Some bugs fixes. - Traduction more complete. - Better code comments for Doxygen documentation. - Better support of vcard export format. - Themes are full CSS compliant.
Features (english version)
  • Fix bug reports of 2.1.0
  • Reported to 2.3.0 Addition of multi-currencies management, only in informative mode at first (Yannick Warnier)
  • Addition of documents history (if invoice generated and sent to the client, keep that precise invoice in this form at all costs - with date)
  • Better database input filtering (prevent easy attacks by disatisfied employees) (continual effort)
  • Reported to 2.3.0 Improvements of invoice-related e-mail sending: configurable default fields, automatical CC to a specified e-mail address, drop-down, title and body language in the contact info (introduce concept of contact language)
  • Reported to 2.3.0 Improvements in the commercial management features. Introduce dated notes, contacts belonging to more than one company, notion of "referral" (a client refers us to another - to keep track of worthy clients)
  • Reported to 2.3.0 Manage members language (e-mail sending)
Modules à inclure/exclure pour la release
Tous les modules du CVS peuvent être inclus dans la release 2.2.0 à l'exception des suivants:
  • Postnuke
Non stable
  • Telephonie
Trop spécifique, présente des failles de sécurité graves
  • ClicktoDial
Hack grossier sur un système peu répandu
  • Bookmark4u
Peu utile
  • Barcode
Non fini
  • Editeur
En cours de dev, non requis
  • Document
Modèles à inclure/exclure pour la release
Modèle numérotation facture
Aucun modele a exclure.
Themes à inclure/exclure pour la release
Tous les themes sont opérationnels sauf 'rodolphe' qui n'a aucun picto.
Autre
  • Le support PostgreSQL n'est pas stable (Manque de testeurs) et ne sera donc pas intégré à la 2.2
  • Le support MSSQL n'est pas stable et ne sera donc pas intégré à la 2.2
