Importing customers automatically
Revision as of 18:25, 2 February 2010 by Eldy (talk | contribs)
This page describes an example of development used to make imports in Dolibarr by coding. If you are looking for other methods, see page Mass imports.
Data file
First you must create your data file and make sure it meets a specific structure:
This file should contain the following fields and must be separated by tabs. The easiest way is to work with excel and then save your document as a tab-delimited text file.
Column1: code_client
Column2: company name
Column3: supplement company name
Column 4: Address Line 1
Column 5: Address Line 2
Colonne6: Address Line 3
Colonne7: Zip Code
Colonne8: City
As you can see the address must be standardized (2 lines for name and 3 lines for the address + ZIP + City). During the import process the 3 address lines will be entered in the single "address" field of Dolibarr with a carriage return after each line. The same will applied for the company name and the company supplement name that will populate the single field "name" of Dolibarr with automatic carriage return.
Colonne9: telephone
Colonne10: fax
Colonne11: email
Colonne12: customer (1 per customer, prospect 2, 0 otherwise)
Colonne13: Provider (1 for supplier or 0 if not vendor)
Colonne14: legal form (See table values llx_c_forme_juridique to feed that column. You can leave this column blank)
Colonne15: type of business (See table values llx_c_typent to feed that column. You can leave this column blank)
Colonne16: Country code (See table values llx_c_pays to feed that column. You can leave this column blank)
Colonne17: url (url of the websites of companies. You can leave this column blank)
Do not add column's header in your file.
Once your columns are filled in, save your file in your data directory under the name societe.txt
Import script file
Copy/paste the content below in a new file and save as "import_client.php" under the directory /scripts
<!doctype html public "-//W3C//DTD HTML 4.0 //EN">
<html>
<head>
       <title>Title here!</title>
</head>
<body>
<?php
'''''$sql_host= "localhost";'''''
'''''$sql_login= "root";'''''
'''''$sql_pass= "";'''''
'''''$sql_base= "nomdevotrebasededonnées";'''''
$dbid = mysql_connect("$sql_host", "$sql_login", "$sql_pass");
mysql_select_db("$sql_base",$dbid);
if(file_exists("'''''../../../mysql/data/demopasspro/societe.txt'''''")) {
	create table if not exists societe_tmp
	 code_client        varchar(15),
	 nom                varchar(60),
	 complement         varchar(60),
	 address1            varchar(255),
	 address2            varchar(255),
	 address3            varchar(255),
	 cp                 varchar(10),
	 ville              varchar(50),
	 tel                varchar(20),
	 fax                varchar(20),
	 email              varchar(128),
	 client             tinyint        DEFAULT 0,
	 fournisseur        tinyint        DEFAULT 0,
	 fk_forme_juridique integer        DEFAULT 0,
	 fk_typent          integer        DEFAULT 0,
	 fk_pays          integer        DEFAULT 0,
	 url          varchar(255)
	$query_content="delete from societe_tmp";
	$result_content=mysql_query($query_content,$dbid);
	$query_content="LOAD DATA INFILE 'societe.txt' into table societe_tmp fields terminated by '\t' ENCLOSED BY '\"' lines terminated by '\r\n'"  ;
	$requete=mysql_query("select * from societe_tmp ") or die("Erreur SQL : $query<br/>".mysql_error());
	$i=0;
	while ($data=mysql_fetch_array($requete))
	$i=$i+1;
	$sql = "INSERT INTO llx_societe (datec, client, nom, address,cp,ville,tel,fax,email,fournisseur,fk_forme_juridique,fk_typent,code_client,fk_pays,url,fk_user_creat) ";
	$valeur_concat='"'.date("Y-m-d H:m:s").'","'.$data['client'].'","'.$data['nom']." ".$data['complement'].'","'.$data['address1']."\\r\n".$data['address2']."\\r\n".$data['address3'].'","'.$data['cp'].'","'.$data['ville'].'","'.$data['tel'].'","'.$data['fax'].'","'.$data['email'].'","'.$data['fournisseur'].'","'.$data['fk_forme_juridique'].'","'.$data['fk_typent'].'","'.$data['code_client'].'","'.$data['fk_pays'].'","'.$data['url'].'","1"';
	$sql .= "VALUES ($valeur_concat);";
	$result_content=mysql_query($sql);
	echo "Nb de clients importés:".$i;
</body>
</html>
Edit the content of this file (the data to modify are in bold italics:
access to the database
path to data according to your tree
All you have to do is open this file with your browser and your data file will be imported.
Hoping it will help some people.
