Module Membership management
Foundations | |
Numero/ID of module | 310 |
Developer doc. of module | Module Foundations (developer) |
- Define several types of member.
- add/Validate/Edit/Resiliate/Delete a member card (characteristics, photos, ...)
- Manage subscriptions is required or not.
- Add/Edit/Delete subscriptions.
- With module EMailing, send mass emailings to members or to a selection of members.
- With module LDAP, synchronize members with a LDAP.
- With module Banks and Cash, interface your subscriptions with treasury of your foundation.
- Reporting.
- Generic export with Module Exports.
Dolibarr can manage your bank accounts but does not manage accoutancy. This means Dolibarr does not suit needs of a big foundation (more than 5000 members). There is also no salary management module. The foundation management modules is however a very god choice if your foundation as a budget lower than 10 000 euros/dollars a year.
Creation of a member type
Creation of personalized attributes
Nouvelle adhésion ou renouvèlement
Résiliation d'adhérent
Example of use case
UCFO01: The foundation wants to define a new type of members | |
Situation | The foundation wants to define a new type of members |
Actions | I create a new type from Menu foundation - Setup - Members types - New type. |
UCFO02: A new member come with a cheque or cash | |
Situation | A new member come with a cheque or cash |
Actions | I create the new member from Menu foundation - New member.
If you want this member to have a Dolibarr access, click on "Create a user" from its member card view. If you want this member to be a third party to send him proposals, invoices, etc, click on "Create a third party" from its member card view. I create a new subscription from tab subscription of member card. |
UCFO03: A member come to renew its subscription with a cheque or cash | |
Situation | A member come to renew its subscription with a cheque or cash |
Actions | I go on the member card then tab Subscriptions.
I add the new subscription. |
UCFO04: I want to revoke a member | |
Situation | I want to revoke a member |
Actions | I go on the member card.
I click on Revoke. |
