Module development
To create a new module/addon for Dolibarr, there is several steps. This tutorial will describe you each of them to build a module to extend Dolibarr features, like one or several of the following :
- Add new tables in database
- Add your own menu entries
- Add new screens to edit new tables
- Add predefined exports for the internal export tool
- Add new information boxes in the home page
- Define new permissions
- Execute code automatically triggered by a particular Dolibarr action
etc... All those operations are possible with version 2.4 or more of Dolibarr.
Create a descriptor of Module (required)
When: Required as soon as an addon is developed, whatever is its goal.
Create your module descriptor
The first step is to create a file descriptor for the module. To do this go into the directory dev/skeletons and copy the file modMyModule.class.php in the directory htdocs/includes/modules. Then change the contents of this file to replace:
- all "modMyModule" with a value which corresponds to the vocation of your module. This value must always start with 'mod'.
- $this->numero = 10000 by a number of free module (Go to Home page -> System Information -> Dolibarr -> Modules to know id the list of modules used).
- Modify any other variables defined in the constructor (see comment in the code skeleton for their meaning).
- Create directory /htdocs/mymodule/
Test your descriptor
Launch Dolibarr and go to page Setup->module? You must see a new line with your new module and the possibility to activate it or not (browse all the tabs of each category of modules to find it). It's value of $this->special that determines in which tab will be your module.
Create your SQL tables and the PHP accessor class (optional)
Create your .sql file
by
Rules to follow:
- Add the files about creating tables commands on the principle of a file llx_matable.sql per table with a possibly file llx_matable.key.sql (see existing files in includes/mysql/tables for examples).
- To manage data, you must create a file called data.sql inside directory /mymodule/sql/ that contains SQL command to add/edit/delete datas.
Test your .sql files
Once the files ready, you can return to Dolibarr to disable the module, dropper tables in database and reactivate the module. The tables should be recreated by the activation of the module. If this is not the case, check your scripts by passing them by hand, or check the Dolibarr logs.
Generate the accessors PHP class
Add your own tabs on entities sheets (optional)
When: To add a tab on an entity (invoices, orders, proposals, member ...)
// where entity can be
// 'thirdparty' to add a tab in third party view
// 'intervention' to add a tab in intervention view
// 'supplier_order' to add a tab in supplier order view
// 'invoice' to add a tab in customer invoice view
// 'order' to add a tab in customer order view
// 'product' to add a tab in product view
// 'propal' to add a tab in proposal view
// 'member' to add a tab in foundation member view
The table should contain a list of strings, each string representing a new tab. The format of the string consisting of 4 parts separated by ":"
- Part 1: The entity code which should appear in the tab is a value from the following:
- 'thirdparty'
- 'intervention'
- 'supplier_order'
- 'supplier_invoice'
- 'invoice'
- 'order'
- 'product'
- 'propal'
- 'member'
- Part 2: The title of the tab. This can be a hard read or better code translation in a file lang.
- Part 3: The name of the file. Lang which contains correspondence between the code translation and language to display.
- Part 4: The url of the page to display when you click on the tab. The __ID__ string will be replaced automatically by the Id of the entity concerned.
Create your own PHP screens (optional)
When: If the purpose of your module is to add features that require new screens.
Create a PHP screen
To create a new user screen, create a subdirectory of htdocs (if not already done) for your module (in htdocs/monmodule for example) to store the pages you will create.
Copy, into that directory, the file skeletons_page.php that will serve as a starting point for your page file and also file pre.inc.php. Edit the file pre.inc.php to have a correct relative path to the main.inc.php file.
This depends on the depth of the directory in which the file is pre.inc.php (Add or remove "../"). It's in the main.inc.php file that is loaded technical environment variables and permissions. The following variables are objects positioned in this file:
- $user Objet that contains the characteristics of the user + his permissions.
- $conf Objet that contains Dolibarr configuration.
- $db Objet that contains an opened connection handler to the database.
- $langs Objet that contains the user's language.
Database access
$db->begin(); // Start transaction
$db->commit(); // Validate transaction
or $db->rollback() // Cancel transaction
To read:
if ($resql)
$num = $db->num_rows($resql);
$i = 0;
if ($num)
while ($i < $num)
if ($obj)
// You can use here results
print $obj->field1;
print $obj->field2;
$i++;
Define style of your pages
You can use for example:
- class="liste_titre" on tags tr and td for the head row of a table.
- class="pair" or class="impair" on tags tr and td of other rows of a table.
- class="flat" on all input fields (input, select, textarea...).
- class="button" on HTML fields with type input type="submit".
Use the Dolibarr date selector
$form=new Form($db);
Add your own setup page (optional)
When: If your module need to ask user several parameters.
If your module need several parameters to be setup, you must create a page to edit options (that will be saved into table llx_const). Create a page named mymodule_setuppage.php that show possibles options and update them into table from a form. It is a necessary to take an example from a page into directory /admin that will show you the way to read/save your parameter. Put this page into directory /admin. Then, into the descriptor file of your module, modify the variable config_page_url to set name of this PHP page (without the path that is not necesary if page is inside directory admin).
Test your page
Go into page Home->Setup->Modules, you should see a picture at the end of the line of your module to reach your setup page. Click on it, you should be able to view/edit parameters from your page.
// Main menu entries
$r=0;
'titre'=>'MyModule top menu',
'mainmenu'=>'mymodule',
'leftmenu'=>'1', // Use 1 if you also want to add left menu entries using this descriptor. Use 0 if left menu entries are defined in a file pre.inc.php (old school).
'position'=>100,
'enabled'=>'1', // Define condition to show or hide menu entry. Use '$conf->mymodule->enabled' if entry must be visible if module is enabled.
'perms'=>'1', // Use 'perms'=>'$user->rights->mymodule->level1->level2' if you want your menu with a permission rules
'target'=>'',
$r++;
$this->menu[$r]=array( 'fk_menu'=>'r=0', // Use r=value where r is index key used for the parent menu entry (higher parent must be a top menu entry)
'position'=>100,
'target'=>'',
$r++;
Add your own permissions (optional)
$this->rights[$r][0] = 10001;
$this->rights[$r][3] = 1;
$r++;
Define you own box (optional)
Define your box
For this, modify the array $this->boxes into the module descriptor file. All you have to do is to add one line for each box file you will create into directory htdocs/includes/boxes
Example:
this->boxes[0][1]='mybox0.php'
this->boxes[1][1]='mybox1.php'
this->boxes[2][1]='mybox2.php'
this->boxes[n][1]='myboxn.php'
Then create files mybox0.php, mybox1.php... by copying an example from an existing box file (into directory htdocs/include/boxes).
Disable and enabled module.
Define your own export (optional)
Define export
Test your export
Define your CSS styles (optional)
Create a style sheet CSS named mymodule.css and put it into directory htdocs/mymodule. You can have only one CSS file per module. Remember it's better to use existing styles already available by default into Dolibarr (The CSS file used by Dolibarr is file themes/mytheme/themename.php.css. Create your own CSS file only if you need absolutely to add not already existing styles. Once your style sheet is ready, declare it into your module descriptor file by modifying the property $this->style_sheet. Value to put here must be a relative URL to your CSS file. For example '/mymodule/myfile.css'.
Test your style sheet
You should see into the HTML header, a line that declare your style sheet.
Define you Javascript functions (optional)
If you need to use your own javascript functions inside your PHP pages, it is necessary to have your functions defined into a javascript file mymodule.js to be included inside the HTML HEAD section. To ask Dolibarr that forge this header to include your own javascript file, you must just declare your file inside the module descriptor.
This feature is not yet available.
Run your own code on any Dolibarr event (optional)
Create a package to distribute and install your module
- Go into the directory /build and copy the file makepack-dolibarrmodules.conf into makepack-mymodule.conf. Warning, this directory may not be provided in some packages of stable versions. If so, it can be retrieved from the CVS snapshot available for download on the Dolibarr website in area "Development version" (taken in this case the whole build directory which is autonomous and independent directory).
- Run the script via Perl (need the Perl version 5.0 or later):
The script asks you the name of your module, its major and minor version. A file mymodule.tgz will then be manufactured containing your module ready to be deployed.
- The person who receives your module must then place the file in the root directory of a Dolibarr installation and perform the command:
tar -xvf monmodule.tgz
- If you want your module to be public, you can submit it (the tgz file) on Dolibarr web site on download area: http://www.dolibarr.org -> downloads -> contrib -> submit a file (you must create an account and be logged to have link appeared).
- If your module was build correctly, file will be validated later.
- If quality is enough and license permits it, code might be added inside main Dolibarr sources (except if you disagree for that).
Some coding rules
Using MDA
