Table llx adherent options
Revision as of 07:53, 9 November 2009 by Simnandez (talk | contribs) (→‎Table)
Content/Contenu/Contenido
  Contains the optional attributes of members of the association module
  Contient les attributs optionnel des adhérents du module association
  Contiene los atributos opcionales de los miembros del módulo miembros
Structure
Table
Versión 1.4 2009/11/07
rowid int(11) NO PRI auto_increment technical index
tms timestamp NO CURRENT_TIMESTAMP last update date
fk_member int(11) NO MUL ID of member (llx_adherent->rowid)
Keys
Version 1.2 2009/10/28
Key Type Fields
PRIMARY PRIMARY optid
idx_adherent_options MULTIPLE adhid
