Module BitTorrent
Revision as of 12:38, 7 November 2009 by Eldy (talk | contribs) (→‎Development)
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
From the application
Manually
unzip modulefile.zip
To complete
Project available into the sourceforge CVS:
ext:sourceforgelogin@dolibarr.cvs.sourceforge.net:/cvsroot/dolibarr
