Error reporting
The error reporting module is integrated in the Dolibarr administration tool and allows you to configure what level of errors you would like to be reported and where.
To get to the error reporting module configuration page, go to Home, Configuration, Modules and use the configuration icon of the last module on the screen: "System logs".
The "facility" option allows you to use pre-set facilities to log your errors in. For example:
- the default "LOG_USER" allows you to record the errors in ...
The next option, "file", allows you to choose a file in which you will store the logs. The path you will indicate there should be relative to the Dolibarr root.
Finally, the level of reporting is how many types of errors you want to report. LOG_DEBUG(7) is the strongest option, reporting pretty much everything that calls a dolibarr_syslog() function. LOG_EMERG(0) is the opposite, letting you see only the errors that would really block your system.
