Module OSCommerceWS (developer)
Revision as of 12:24, 7 November 2009 by Eldy (talk | contribs) (→‎Features)
OSCommerceWS
Numero/ID of module 900
User doc. of module Module OSCommerceWS
The OSCommerceWS module is used to synchronize informations between OSCommerce and Dolibarr using Web services.
By this way, it is possible to
  • publish into OSCommerce some products created into Dolibarr.
  • import orders (and details) from OSCommerce into Dolibarr.
  • import customers fomr OSCommerce into Dolibarr.
This module works using the NuSOAP library embedded into Dolibarr.
Code
All source code for this module is available inside directory htdocs/oscommerce_ws.
Source code you can find into directory htdocs/boutique is dedicated to Module OSCommerce (developer) that works differently.
The directory ws_server/ must be copied onto the OSCommerce server, inside directory catalog/. It must then be configured, by modifying the file ws_server/includes/configuration.php to define the OSCommerce configuration (how to access databases).
Permissions
Tables SQL
None
