Table llx product
Revision as of 03:02, 6 August 2007 by Ywarnier (talk | contribs)
Catégorie:Table SQL
 La documentation relative aux autres tables est disponible sur la page Liste des tables
 The documentation related to other tables is available on the tables list page: Liste des tables
Contenu
Cette table contient les produits et services.
Contains the list of products and services.
Structure
| Field              | Type         | Null | Key | Default           | Extra          |
| rowid              | int(11)      | NO   | PRI | NULL              | auto_increment |
| datec              | datetime     | YES  |     | NULL              |                |
| tms                | timestamp    | NO   |     | CURRENT_TIMESTAMP |                |
| ref                | varchar(32)  | NO   | UNI |                   |                |
| label              | varchar(255) | NO   |     |                   |                |
| description        | text         | YES  |     | NULL              |                |
| note               | text         | YES  |     | NULL              |                |
| price              | double(16,8) | YES  |     | NULL              |                |
| price_ttc          | double(16,8) | YES  |     | 0.00000000        |                |
| price_base_type    | varchar(3)   | YES  |     | HT                |                |
| tva_tx             | double(6,3)  | YES  |     | NULL              |                |
| fk_user_author     | int(11)      | YES  |     | NULL              |                |
| envente            | tinyint(4)   | YES  |     | 1                 |                |
| nbvente            | int(11)      | YES  |     | 0                 |                |
| fk_product_type    | int(11)      | YES  |     | 0                 |                |
| duration           | varchar(6)   | YES  |     | NULL              |                |
| stock_propale      | int(11)      | YES  |     | 0                 |                |
| stock_commande     | int(11)      | YES  |     | 0                 |                |
| seuil_stock_alerte | int(11)      | YES  |     | 0                 |                |
| stock_loc          | varchar(10)  | YES  |     | NULL              |                |
| gencode            | varchar(255) | YES  |     | NULL              |                |
| weight             | float        | YES  |     | NULL              |                |
| weight_units       | tinyint(4)   | YES  |     | NULL              |                |
| volume             | float        | YES  |     | NULL              |                |
| volume_units       | tinyint(4)   | YES  |     | NULL              |                |
| canvas             | varchar(15)  | YES  |     |                   |                |
