Setup EMails
Revision as of 14:42, 1 November 2009 by Eldy (talk | contribs)
Help about screen: EMail setup
Menu path: Home -> Setup -> EMails
The EMails setup screen allows you to setup Dolibarr to send EMails and to test your setup.
Setup parameters
This is explanation of all setup parameters:
Disable globally all emails sendings (test mode or demo)
Set this to No. If you set to yes (for a demo system for example), no more mail will be sent.
Method to send emails
The default method is PHP mail function. This means that Dolibarr use your PHP to send emails. The choice Simplemail class do the same thing. If your email sending server needs authentication, you must choose SMTP/SMTP-AUTH, validate, this will make the field login or password appears on this page.
Hostname or ip address of SMTP/SMTPS sending server
Name or IP address of the server that send mail. It is usually an name like smtp.xxx.zzz provided by your Internet Service Provider. For example: smtp.aol.com, smtp.free.fr, smtp.myprovider.com
Port of SMTP/SMTPS sending server
If the email sending server use the standard port (25), you can let the field empty.
SMTP Authentification ID
Visible if you have choose SMTP-AUTH as sending method. Put here your login.
Visible if you have choose SMTP-AUTH as sending method. Put here your password.
Usage of TLS (SSL)
Some emails servers require SSL encrypted communication (For example the SMTP server of Google smtp.gmail.com). It's SMTPS.
The only method that support this protocol is "SMTP/SMTPS socket library". You can enable cryptography by setting this parameter to Yes.
Note: SSL functions must be available in your PHP. If not, you probably forget to install the openssl module of PHP.
EMail used as sender for automatic emails
EMail that will be used by Dolibarr as emails sender if sender is not explicitly defined.
Actions
Test server availability
This button is to test if you can communicate with the server. This allow you validate the parameter:
  • Hostname or ip address of SMTP/SMTPS sending server
  • Port of SMTP/SMTPS sending server
  • Usage of TLS (SSL)
Test send email
This button is to test what happens when you send an email with simple text content.
Test send email HTML
This button is to test what happens when you send an email with HTML content.
