Module Membership management
Revision as of 23:25, 31 October 2009 by Eldy (talk | contribs) (→‎Usage)
Foundations
Numero/ID of module {{{num}}}
  • Reporting.
Dolibarr can manage your bank accounts but does not manage accoutancy. This means Dolibarr does not suit needs of a big foundation (more than 5000 members). There is also no salary management module. The foundation management modules is however a very god choice if your foundation as a budget lower than 10 000 euros/dollars a year.
Creation of a member type
Creation of personalized attributes
Creation of a memeber
Diagramme d'états d'un adhérent
Résiliation d'adhérent
Exemples de cas d'utilisation
L'association définie un nouveau type d'adhérent
Je vais sur la fiche adhérent puis onglet Adhésion. Je saisie une nouvelle adhésion.
Je résilie un adhérent car son adhésion a expirée et non renouvelée depuis longtemps
