Table llx events
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains saved security events (readable by admin users on menu system tools - audit)
Contient les évènements sauvegardés d'audit de sécurité (consultable par les utilisateurs administrateurs dans le menu outils system - audit)
Contiene los eventos de seguridad (consultables por los usuarios administradores en el menú utilidades sistema - auditoría)
Structure
Table
Version 1.2 2009/10/20
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | NO | PRI | auto_increment | technical index | |
| tms | timestamp | NO | CURRENT_TIMESTAMP | last update date | ||
| type | varchar(32) | NO | type of event (list of supported events are found in the trigger htdocs/includes/triggers/interface_all_Logevents.class.php) | |||
| entity | int(11) | NO | 1 | multi company id | ||
| dateevent | datetime | YES | MUL | NULL | date of event | |
| fk_user | int(11) | YES | NULL | ID user (llx_user->rowid) | ||
| description | varchar(250) | NO | full description of event | |||
| ip | varchar(32) | NO | ip of user | |||
| user_agent | varchar(128) | YES | NULL | user agent | ||
| fk_object | int(11) | YES | NULL | ID of object (any table_of_related_object->rowid) |
Keys
Version 1.1 2009/10/07
| Key | Type | Fields |
| PRIMARY | PRIMARY | rowid |
| idx_events_dateevent | MULTIPLE | dateevent |
