Table llx element contact
Revision as of 06:44, 27 October 2009 by Simnandez (talk | contribs) (→‎Keys)
Content/Contenu/Contenido
  This table allows to save links between an entity and a contact from third parties. For example, when an order must be linked to a delivery contact in particular , we use this table.
  Cette table permet de sauvegarder les liens entre une entité et un contact de tiers. Par exemple quand une commande doit être lié à un contact de livraison particulier, on utilisera cette table.
  Esta tabla le permite guardar los enlaces entre las entidades y los contactos. Por ejemplo, cuando un pedido debe estar vinculado a un contacto de envío en particular, utilizaremos esta tabla.
Structure
Table
Version 1.1 2009/10/07
rowid int(11) NO PRI auto_increment technical index
datecreate datetime YES NULL creation date of link
statut smallint(6) YES 5 link status (5=inactive; 4=active)
element_id int(11) NO UNI ID of element (any table_of_elements->rowid)
fk_c_type_contact int(11) NO UNI ID of type of contact (llx_c_type_contact->rowid)
fk_socpeople int(11) NO UNI ID of contact (llx_socpeople->rowid)
Keys
Version 1.2 2009/10/24
Key Type Fields
PRIMARY PRIMARY rowid
idx_element_contact_idx1 UNIQUE element_id,fk_c_type_contact,fk_socpeople
fk_element_contact_fk_c_type_contact MULTIPLE fk_c_type_contact
idx_element_contact_fk_socpeople MULTIPLE fk_socpeople
