Table llx menu
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the menus.
Contient les menus.
Contiene los menús.
Structure
Table
Version 1.1 2009/10/07
Field | Type | Null | Key | Default | Extra | Description |
rowid | int(11) | NO | PRI | auto_increment | technical index | |
menu_handler | varchar(16) | NO | UNI | Menu handler name | ||
entity | int(11) | NO | UNI | 1 | multi company id | |
module | varchar(64) | YES | NULL | module name if record is added by a module | ||
type | varchar(4) | NO | MUL | type of menu (top or left) | ||
mainmenu | varchar(100) | NO | Name family/module (home, companies, etc.) | |||
fk_menu | int(11) | NO | UNI | 0 or Id of mother menu line | ||
position | int(11) | NO | sort order of entry | |||
url | varchar(255) | NO | UNI | relative (or absolute) url to go | ||
tarjet | varchar(100) | YES | NULL | target of url link | ||
titre | varchar(255) | NO | key for menu translation | |||
langs | varchar(100) | YES | NULL | lang file to load for translation | ||
level | tint(1) | YES | NULL | only used by auguria menu. Do not use | ||
leftmenu | varchar(1) | YES | 1 | say if left menu defined in pre.inc.php and used by top menu must be overwritten by dynamic databse menu (1=yes by default) | ||
perms | varchar(255) | YES | NULL | condition to show enabled or disabled | ||
enabled | varchar(255) | YES | 1 | condition to show or hide | ||
user | int(11) | NO | 0 | 0 if menu for all users, 1 for external only, 2 for internal only | ||
tms | timestamp | NO | CURRENT_TIMESTAMP | last update date |
Keys
Key | Type | Fields |
PRIMARY | PRIMARY | rowid |
idx_menu_uk_menu | UNIQUE | menu_handler,fk_menu,url,entity |
idx_menu_menuhandler_type | MULTIPLE | menu_handler,type |
