Table llx menu
Content/Contenu/Contenido
En verysmall.png Contains the menus.
Fr verysmall.png Contient les menus.
Es verysmall.png Contiene los menús.
Structure
Table
Version 1.1 2009/10/07
rowid int(11) NO PRI auto_increment technical index
menu_handler varchar(16) NO Menu handler name
entity int(11) NO 1 multi company id
module varchar(64) YES NULL module name if record is added by a module
type varchar(4) NO type of menu (top or left)
mainmenu varchar(100) NO Name family/module (home, companies, etc.)
fk_menu int(11) NO 0 or Id of mother menu line
position int(11) NO sort order of entry
url varchar(255) NO relative (or absolute) url to go
tarjet varchar(100) YES NULL target of url link
titre varchar(255) NO key for menu translation
langs varchar(100) YES NULL lang file to load for translation
level tint(1) YES NULL only used by auguria menu. Do not use
leftmenu varchar(1) YES 1 say if left menu defined in pre.inc.php and used by top menu must be overwritten by dynamic databse menu (1=yes by default)
perms varchar(255) YES NULL condition to show enabled or disabled
enabled varchar(255) YES 1 condition to show or hide
user int(11) NO 0 0 if menu for all users, 1 for external only, 2 for internal only
tms timestamp NO CURRENT_TIMESTAMP last update date
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_menu_uk_menu UNIQUE menu_handler,fk_menu,url,entity
idx_menu_menuhandler_type MULTIPLE menu_handler,type
