Table llx fichinter
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the interventions of the interventions module. The interventions details are in Table_llx_fichinterdet
Cette table contient les enregistrements des interventions du module interventions. Les détails de les interventions sont dans la Table_llx_fichinterdet
Contiene los registros de intervenciones del módulo intervenciones. Los detalles de las intervenciones se encuentran en la Table_llx_fichinterdet
Structure
Table
Version 1.1 2009/10/07
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | NO | PRI | auto_increment | technical index | |
| fk_soc | int(11) | YES | MUL | ID of related society (llx_societe->rowid) | ||
| fk_projet | int(11) | YES | 0 | ID of related proyect (llx_projet->rowid) | ||
| fk_contract | int(11) | YES | 0 | ID of related contract (llx_contrat->rowid) | ||
| ref | varchar(30) | NO | UNI | reference | ||
| entity | int(11) | NO | UNI | 1 | multi company id | |
| tms | timestamp | NO | CURRENT_TIMESTAMP | last update date | ||
| date_c | datetime | YES | NULL | creation date | ||
| date_valid | datetime | YES | NULL | validation date | ||
| datei | date | YES | NULL | livration date | ||
| fk_user_author | int(11) | YES | NULL | ID creator user (llx_user->rowid) | ||
| fk_user_valid | int(11) | YES | NULL | ID validator user (llx_user->rowid) | ||
| fk_statut | smallint(6) | YES | 0 | |||
| duree | real | YES | NULL | intervention duration | ||
| description | text | YES | NULL | comentary | ||
| note_private | text | YES | NULL | comentary | ||
| note_public | text | YES | NULL | public comentary | ||
| model_pdf | varchar(50) | YES | NULL | Model PDF to print |
Keys
| Key | Type | Fields |
| PRIMARY | PRIMARY | rowid |
| uk_fichinter_ref | UNIQUE | ref,entity |
| idx_fichinter_fk_soc | UNIQUE | fk_soc |
