Table llx commande fournisseurdet
Content/Contenu/Contenido
  Contains details of providers orders. This table is linked to Table llx_commande_fournisseur
  Contient les détails des commandes fournisserus, cette table est liée avec la Table llx_commande_fournisseur
  Contiene los detalles de los pedidos a proveedores, esta tabla esta vinculada con Table llx_commande_fournisseur
Structure
Tables
Version 1.1 2009/10/07
rowid int(11) NO PRI auto_increment technical index
fk_commande int(11) NO ID of order (llx commande->rowid)
fk_product int(11) YES NULL ID of product (llx_product->rowid)
ref varchar(50) YES NULL supplier ref. of product
label varchar(255) YES NULL label of product
description text YES NULL product description
tva_tx double(6,3) YES 0.000 VAT taxes
qty real YES NULL Quantity of product
remise_percent real YES 0 discount percentage
remise real YES 0 discount amount
subprice double(24,8) YES 0.00000000 unit price before
total_ht double(24,8) YES 0.00000000 total excluding tax
total_tva double(24,8) YES 0.00000000 total tax
total_ttc double(24,8) YES 0.00000000 total with tax
product_type int(11) YES 0 type of product
date_start datetime YES NULL start date if service
date_end datetime YES NULL end date if service
info_bits int(11) YES 0 TVA NPR or not
Keys
Key Type Fields
PRIMARY PRIMARY rowid
