Table llx boxes def
Revision as of 07:41, 19 October 2009 by Simnandez (talk | contribs) (→‎Keys)
Content/Contenu/Contenido
En verysmall.png Contains the active boxes
Fr verysmall.png Contient les boîtes actives
Es verysmall.png Contiene las cajas activas.
Structure
Table
Version 1.1 2009/10/07
rowid int(11) NO PRI auto_increment technical index
file varchar(255) NO box file.php
entity int(11) NO PRI 1 multi company id
tms timestamp NO CURRENT_TIMESTAMP last update date
note text YES NULL comments
Keys
Version 1.2 2009/10/17
Key Type Fields
PRIMARY PRIMARY rowid
uk_boxes_def UNIQUE file,entity
