Table llx bank
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the transactions operated on bank accounts.
Contient les opérations effectuées sur les comptes bancaires.
Contiene las transaccions efectuadas en las cuentas bancarias.
Structure
Table
Version 1.1 2009/10/07
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | NO | PRI | auto_increment | technical index | |
| datec | datetime | YES | NULL | date of creation technical | ||
| datev | date | YES | MUL | NULL | value date of the transaction | |
| dateo | date | YES | MUL | NULL | date of the transaction | |
| amount | double(24,8) | NO | 0.00000000 | amount of the transaction | ||
| label | varchar(255) | YES | NULL | label | ||
| fk_account | int(11) | YES | MUL | NULL | account number on which the transaction took place | |
| fk_user_author | int(11) | YES | NULL | ID of user author of the information (llx_user->rowid) | ||
| fk_user_rappro | int(11) | YES | NULL | ID of user author of the rapprochement (llx_user->rowid) | ||
| fk_type | varchar(4) | YES | NULL | transaction type | ||
| num_releve | varchar(50) | YES | NULL | number of summary of the bank on which the transaction | ||
| num_chq | int(11) | YES | NULL | number of check if significant | ||
| rappro | tinyint(4) | YES | MUL | 0 | indicates whether the line was rapproched or not | |
| note | text | YES | NULL | note | ||
| fk_bordereau | int(11) | YES | 0 | Id du bordereau de remise de cheque | ||
| banque | varchar(255) | YES | NULL | name of the bank received the check | ||
| emetteur | varchar(255) | YES | NULL | name of the issuer of the check | ||
| author | varchar(40) | YES | NULL | to delete after migration |
Keys
| Key | Type | Fields |
| PRIMARY | PRIMARY | rowid |
| idx_bank_datev | MULTIPLE | datev |
| idx_bank_dateo | MULTIPLE | dateo |
| idx_bank_fk_account | MULTIPLE | fk_account |
| idx_bank_rappro | MULTIPLE | rappro |
