Table llx c paper format
Content/Contenu/Contenido
  Contains the list of available papers format to print.
  Contient la liste des formats de papier disponibles pour l'impression.
  contiene la lista de los formatos disponibles de papel para imprimir.
Structure
rowid int(11)   PRI NULL auto_increment technical index
code varchar(16) code of format
label varchar(50) label of format
width float(6,2) YES 0.00 width of papier
height float(6,2) YES 0.00 height of papier
unit varchar(5) unit of measure
active tinyint(4) NO 1 is the papier format active?
