Module SpeedFinder
Revision as of 11:04, 23 September 2009 by Simnandez (talk | contribs)
With this module, Dolibarr is able to show a menu for quick search of contacts or societies by entering a few digits of the phone.
From the application
Manually
unzip modulefile.zip
There are 2 ways to access SpeedFinder:
  • Via the standard menu of Dolibarr (top menu)
  • By activating the "Popup" configuration mode, then it is possible to click on a popup link (in the main screen SpeedFinder) and open a standalone window.
Then you only have to enter one part of telephone number to see all contacts associated.
Example: Dolibarr is open in your Navigator and you receive a call from a customer or supplier:
   1. you see the number of the caller (if your phone allows)
   2. clicking on the menu SpeedFinder of your Dolibarr
   3. you enter 2 or 3 digits in the "Quick Search:: phone"
   4. list of names associated dynamically appears almost instantaneously (via AJAX)
   5. clicking on the name to go directly to the page of your partner
The entire operation lasted less than 5 seconds (the time to pick up the phone) ... you want say "hello" to caller (calling him by his name) ... and details for the actions and current proposal is already under your eyes!
Development of this module is not included inside standard CVS repository of Dolibarr but into the complementary modules area. So source code is hosted into following CVS repository:
  • CVS Repository: :ext:savannahlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr
  • CVS Module: dolibarrmod
To have a view on changes done on this repository, see page http://www.nltechno.com/stats/dolibarr/cvschangelogbuilder_dolibarrmod.html
