Table llx projet task
Revision as of 07:36, 2 September 2009 by Simnandez (talk | contribs) (→‎Structure)
Content/Contenu/Contenido
En verysmall.png Contains tasks related to a project.
Fr verysmall.png Contient des tâches liées à un projet.
Es verysmall.png Contiene las tareas relacionadas a un proyecto.
Structure
rowid int(11)   PRI NULL auto_increment technical index
fk_projet int(11) NO ID of proyect (llx_projet->rowid)
fk_task_parent int(11) NO ID of task (llx_c_actioncomm->id)
title varchar(255) YES NULL task title
duration_effective real NO duration of task
fk_user_creat int(11) YES NULL ID of creator user (llx_user->rowid)
fk_statut varchar(6) YES open status
note text YES NULL comentary notes
