Roadmap and Release 2.4.0 ("Popularity" version)
Revision as of 12:37, 30 August 2009 by Eldy (talk | contribs) (moved Roadmap 2.4.0 to Roadmap 2.4.0 ("Popularity" version))
Version: 2.4.0 (List of other versions on page Category:RoadMap)
Release date: 2008-08-22
- Version called "Popularity" (1st version with promotion on Internet)
Detailed Changelog:
For users: - Add a calendar module (module agenda) with ical/vcal/rss export. - Look enhancement in graphics (thanks artichow). - Add tel and fax on delivery addresses. - Add a tool to edit personalized menu. - Add an ical and vcal export link in agenda and webcalendar module. - Reduce memory usage. - Now triggers are enabled/disabled according to module they refers to. - Fix infinite loop on popup calendar. - Change in tanslation to make Dolibarr easier to understand. - Add a warning when sending a mail from a user with no email defined. - Added clicktodial module. - Add a property private/public in contact. This allows to user Dolibarr for a personnal address book. - French NAF code can accept 5 chars. - Supplier prices can be input with or without taxe. - New generic numbering modules to offer more solutions for generating automatic id. - Add new predefined exports wizards (stocks, suppliers, taxes...). - Add feature to log security events (logon, change of users, passwords). - Can link all documents (included supplier invoices and orders) to a project. - Can attach several files to email when sending an invoice, order or proposal by email. - Can choose accuracy (number of decimals) for prices. - Localization for decimal and thousand delimiter on number is fully supported. - More informations reported in system information pages. - Add a budget report. - Added a security audit report. - Other minor changes (features, look, fixes) - Added compatibility with Firefox 3. - Changes for compatibility with PHP6/Mysql6. - Some bug fixes. For translators: - Added spanish es_ES translation. - Added en_AU translation. For developers: - Removed useless code: Replaced phplot and phplot5 librairies by artichow. Removed cryptograph library replaced by artichow. - Login functions are now externalised as modules. - Update code skeletons examples. - Several enhancements to make addon development easier. - Add a tool to generate PHP classes completely mapped to a table. - Added a check to enable external modules only if dolibarr version is high enough. - Changes in wizard installer to allow building autoexe installer for Windows with Apache and Mysql included.
