Roadmap and Release 2.2.0 ("Purged version")
Version: 2.2.0 (List of other versions on page Category:RoadMap)
Release date: 2007-12-26
- Called "Purge version" (a lot of old deprecated files were removed)
Detailed ChangeLog:
- Add more statistics on main page. - Add option to add message on login page. - Management of categories for third parties. - Add volume on products properties. - Support for LDAP authentication. - Full member synchronisation with LDAP database in fundation module. - More LDAP fields supported for user synchronization. - Better logger for install. - First changes to support UTF8. - Add a "forget password" feature. - Setup process can run several migrate files if need to jump several versions to upgrade. - Support for webcalendar 1.1 in webcalendar module. - Support for menu in database. - Better support for using Dolibarr on more WHP. - Removed some deprecated files and clean code. - New theme: Auguria - Removed PHP warnings. - Some bugs fixes. - Traduction more complete. - Better code comments for Doxygen documentation. - Better support of vcard export format. - A lot of security enhancements (no more password in log files, crypted password in database, in config file...). - Themes are full CSS compliant. - A lot of other minor changes... - Option to scan uploaded document by an antivirus. - Transparency for picto files works with IE. - Can drag and drop boxes on main page.
