Module NumberWords
With this module, Dolibarr is able to translate decimal number or amount into full text strings ("110 dollars" will give "one hundred and ten dollars")
From the application
Manually
unzip modulefile.zip
- If you are an end user: add the string __TOTAL_TTC_WORDS__ in any "free text for PDF" area in setup of invoices, orders, proposals... This string will we replaced with the amount of invoice in full text .
- If you are a developper: You can also use, anywhere in the code, the method
$langs->getLabelFromNumber($mynumber,0|1)
to get full text string of a number or amount.
To complete
