Module LDAP En
Revision as of 10:21, 12 August 2009 by Eldy (talk | contribs)
Category LDAP
The LDAP module must be used if you want to synchronize somer Dolibarr entities with a LDAP database. The entities and direction you can synchronize are:
  • User -> LDAP
  • Groups -> LDAP
  • Contact -> LDAP
  • LDAP -> Contacts
  • Members -> LDAP
Information you must supply in the LDAP module setup are:
  • LDAP server information (ip, port...)
  • Choose which synchronization you want
  • Enter the organization of your LDAP tree
  • Make matching between Dolibarr fields and LDAP fields.
For synchronization from Dolibarr to LDAP, once your setup is done, there is nothing to do. Each time you make a change in Dolibarr, the change is also saved into your LDAP.
