Module Pibarcode
Revision as of 16:20, 10 August 2009 by Eldy (talk | contribs) (→‎Setup)
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
From the application
Manually
unzip modulefile.zip
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
To complete
