Module Membership management (developer)
Revision as of 16:19, 6 August 2009 by Eldy (talk | contribs) (moved Module Foundations to Module Foundations (developer))
Foundations | |
Numero/ID of module | {{{num}}} |
User doc. of module | Foundations |
Developer doc. of module | This page |
Feature
Le module des adhérents permet de gérer les membres d'une association ou d'un club. Il est possible de définir différent types d'adhérents, de stocker des informations et de recenser leur cotisation.
Numéro : 310
Entity Member
The PHP class to use to manipulate such object is file htdocs/adherent.class.php.
Permissions
- ->adherent->lire
- ->adherent->creer
- ->adherent->supprimer
- ->adherent->export
- ->adherent->configurer
- ->adherent->self->creer
- ->adherent->cotisation->lire
- ->adherent->cotisation->creer
Tables SQL
- llx_adherent Contient la liste des adhérents
- llx_adherent_options
- llx_adherent_options_label
- llx_adherent_type Contient les différents types d'adhérents
