Template:ActivationModuleEn
Revision as of 10:37, 3 August 2009 by Eldy (talk | contribs) (Created page with 'To use this module, you must first enable it. For this, with an administrator use, go on page "Home - Setup - Modules". Choose the tab where the module stand. Then click on "Acti...')
To use this module, you must first enable it. For this, with an administrator use, go on page "Home - Setup - Modules". Choose the tab where the module stand. Then click on "Activate". The module should be ready to be used. Sometimes a picto appears at end of module line. Click on it, to access the setup page specific to this module.
