Table llx facturedet rec
Content/Contenu/Contenido
En verysmall.png Contains the lines of predefined invoices, this table is linked with Table llx_facture_rec.
Fr verysmall.png Contient les lignes des factures prédéfinies, cette table est liée avec la Table llx_facture_rec.
Es verysmall.png Contiene las líneas de las facturas predefinidas, esta tabla está vinculada con Table llx_facture_rec.
Structure
rowid int(11)   PRI NULL auto_increment technical index
fk_facture int(11) NO ID of related facture (llx_facture_rec->rowid)
fk_product int(11) YES NULL ID of related product (llx_product->rowid)
product_type int(11) NO 0 type of product
description text YES description of product
datec datetime YES NULL creation date
tva_taux double YES 19.6 VAT tax
qty double YES NULL quantity
remise double YES 0 discount
remise_percent double YES 0 percent discount
price double YES NULL final price
subprice double YES NULL price before discount
total_ttc double YES NULL total with tax
total_ht double YES NULL total excluding tax
total_tva double YES NULL total tax
