Module development
To create a new module/addon ofr Dolibarr, there is several steps. This tutotial will describe you each of them to build a module to extend Dolibarr features, like one or several of the following :
- Add new tables in database
- Add your own menu entries
- Add new screens to edit new tables
- Add predefined exports for the internal export tool
- Add new information boxes in the home page
- Define new permissions
- Execute code automatically triggered by a particular Dolibarr action
etc... All those operations are possible with version 2.4 or more of Dolibarr.
Create a descriptor of Module (required)
When: Required as soon as an addon is developped, whatever is its goal.
Create your module descriptor
The first step is to create a file descriptor for the module. To do this go into the directory dev/skeletons and copy the file modMyModule.class.php in the directory htdocs/includes/modules. Then change the contents of this file to replace:
* all "modMyModule" with a value which corresponds to the vocation of your module. This value must always start with 'mod'. * $this->numero = 10000 by a number of free module (Go to Home page -> System Information -> Dolibarr to know id the list of modules used). * $this->const_name = 'MAIN_MODULE_MYMODULE' by $this-> const_name = 'MAIN_MODULE_XXX' where XXX must match the value chosen to replace MyModule and put in capitalized. * $dir = DOL_DOCUMENT_ROOT.'/mysql/tables/mymodule/'; by $dir = DOL_DOCUMENT_ROOT.'/mysql/tables where xxxxxxxx is the name of your module (without spaces). * Modify any other variables defined in the constructor (see comment in the code skeleton for their meaning).
Test your descriptor
Launch Dolibarr and go to page Setup->module? You must see a new line with your new module and the possibility to activate it or not (browse all the tabs of each category of modules to find it). It's value of $this->special that determines in which tab will be your module.
Create your SQL tables and the PHP accessor class (optionnal)
Create your .sql file
by
Rules to follow:
- Add the files about creating tables commands on the principle of a file llx_matable.sql per table with a possibly file llx_matable.key.sql (see existing files in mysql/tables for examples).
- To manage data, you must create a file called data.sql inside directory /mymodule/sql/ that contains SQL command to add/edit/delete datas.
Test your .sql files
Once the files ready, you can return to Dolibarr to disable the module, dropper tables in database and reactivate the module. The tables should be recreated by the activation of the module. If this is not the case, check your scripts by passing them by hand, or check the Dolibarr logs.
Generate the accessors PHP class
Add your own tabs on entities sheets (optionnal)
When: To add a tab on an entity (invoices, orders, proposals, member ...)
// where entity can be
// 'thirdparty' to add a tab in third party view
// 'intervention' to add a tab in intervention view
// 'supplier_order' to add a tab in supplier order view
// 'invoice' to add a tab in customer invoice view
// 'order' to add a tab in customer order view
// 'product' to add a tab in product view
// 'propal' to add a tab in propal view
// 'member' to add a tab in fundation member view
The table should contain a list of strings, each string representing a new tab. The format of the string consisting of 4 parts separated by ":"
- Part 1: The entity code which should appear in the tab is a value from the following:
- 'thirdparty'
- 'intervention'
- 'supplier_order'
- 'supplier_invoice'
- 'invoice'
- 'order'
- 'product'
- 'propal'
- 'member'
- Part 2: The title of the tab. This can be a hard read or better code translation in a file lang.
- Part 3: The name of the file. Lang which contains correspondence between the code translation and language to display.
- Part 4: The url of the page to display when you click on the tab. The __ID__ string will be replaced automatically by the Id of the entity concerned.
Créer une page écran PHP
Vous devez ensuite créer vos pages PHP qui se basent sur les données de vos tables en utilisant les squelettes fournis comme exemple dans le répertoire dev/skeletons (Pour le développement d'un script en ligne de commande, voir Developpement_script).
Y recopier le fichier skeletons_page.php qui va servir de point de départ à votre page ainsi que le fichier pre.inc.php. Modifier le fichier pre.inc.php afin que le chemin relatif du
soit correct, en fonction de la profondeur de répertoire dans laquelle se trouve le fichier pre.inc.php (Enlever ou supprimer des "../"). C'est dans le main qu'est chargé l'environnement technique ainsi que les habilitations. Les variables objets suivantes sont alors positionnées:
- $db L'objet qui contient le handler de connexion ouvert à la base de donnée.
Accès à la base
Si vous avez besoin de réaliser des modifications en base dans votre propre table ajouté, utilisez la classe générée plus haut.
$db->commit(); // Valide
ou $db->rollback() // Annule
Pour une lecture:
if ($resql)
$num = $db->num_rows($resql);
$i = 0;
if ($num)
while ($i < $num)
if ($obj)
// You can use here results
print $obj->field1;
print $obj->field2;
$i++;
Définition du style
Par exemple:
$form=new Form($db);
print $form->select_date('','mykey',0,0,0,"myform");
$datefacture = dolibarr_mktime(12, 0 , 0, $_POST['mykeymonth'], $_POST['mykeyday'], $_POST['mykeyyear']);
print strftime('%A %d %B %Y', $datefacture);
Tester votre page
Aller sur la page Configuration->module, vous devez voir apparaitre un icone qui permet d'accéder à la page de configuratione tvous devez etre capable de modifier ces options et les voir conservé en base.
Définissez vos entrées
Pour cela, il vous faut définir dans le fichier descripteur de menu le tableau
$this->menu
Ce tableau contient toutes les entrées qui apparaitront dans les menus une fois le module activé. Les fichiers de descripteur de module exemple possède un exemple de déclaration de menu haut ainsi que de ces entrées menu gauche correspondantes.
Désactiver et réactiver votre module sous Dolibarr, les entrées menus doivent alors apparaitre.
La définition des permissions que gèrera votre module se fait dans le fichier descripteur créé dans la première étape. Modifier la ligne $this->rights_class = 'facture' par
Ensuite remplissez le tableau $this->rights avec autant d'entrée que de permissions différentes à gérer.
$this->rights[$r][0] = 10001; $this->rights[$r][1] = 'Libelle par défaut de ma permission'; $this->rights[$r][3] = 1; $this->rights[$r][4] = 'action'; $this->rights[$r][5] = 'sousaction'; $r++;
Définissez vos box
Exemple:
this->boxes[0][1]='mabox0.php' this->boxes[1][1]='mabox1.php' this->boxes[2][1]='mabox2.php' ... this->boxes[n][1]='maboxn.php'
Aller dans le menu Accueil - Configuration - Boite. Vos boxs doivent apparaitre dans la liste des box activables. Avticer les, aller sur la page d'accueil et vérifier qu'elles s'affichent correctement.
Définissez l'export
Tester votre export
Tester votre feuille de style
Assurez vous que votre module est actif. Appelez la page d'accueil de Dolibarr. Afficher la source de la page HTML. Vous devriez voir dans l'entête HTML, une ligne déclarant votre feuille de style.
Quand: Si vous voulez que des actions particulières s'exécutent suite au déclenchement d'action s standards de Dolibarr (exemple: je veux mettre à jour une table de mon module quand une facture se crée dans Dolibarr), il vous faut créer un fichier de triggers.
Voir aussi Interfaces_Dolibarr_vers_exterieur et Interfaces_Exterieur_vers_Dolibarr
Create a package to distribute and install your module
- Go into the directory /build and copy the file makepack-dolibarrmodules.conf into makepack-mymodule.conf. Warning, this directory may not be provided in some packages of stable versions. If so, it can be retrieved from the CVS snapshot available for download on the Dolibarr website in area "Development version" (taken in this case the whole build directory which is autonomous and independent directory).
- Run the script via Perl (need the Perl version 5.0 or later):
The script asks you the name of your module, its major and minor version. A file mymodule.tgz will then be manufactured containing your module ready to be deployed.
- The person who receives your module must then place the file in the root directory of a Dolibarr installation and perform the command:
tar -xvf monmodule.tgz
Some coding rules
Using MDA
