Module development
To create a new module/addon ofr Dolibarr, there is several steps. This tutotial will describe you each of them to build a module to extend Dolibarr features, like one or several of the following :
  • Add new tables in database
  • Add your own menu entries
  • Add new screens to edit new tables
  • Add predefined exports for the internal export tool
  • Add new information boxes in the home page
  • Define new permissions
  • Execute code automatically triggered by a particular Dolibarr action
etc... All those operations are possible with version 2.4 or more of Dolibarr.
Create a descriptor of Module (required)
When: Required as soon as an addon is developped, whatever is its goal.
Create your module descriptor
The first step is to create a file descriptor for the module. To do this go into the directory dev/skeletons and copy the file modMyModule.class.php in the directory htdocs/includes/modules. Then change the contents of this file to replace:
   * all "modMyModule" with a value which corresponds to the vocation of your module. This value must always start with 'mod'.
   * $this->numero = 10000 by a number of free module (Go to Home page -> System Information -> Dolibarr to know id the list of modules used).
   * $this->const_name = 'MAIN_MODULE_MYMODULE' by $this-> const_name = 'MAIN_MODULE_XXX' where XXX must match the value chosen to replace MyModule and put in capitalized.
   * $dir = DOL_DOCUMENT_ROOT.'/mysql/tables/mymodule/'; by $dir = DOL_DOCUMENT_ROOT.'/mysql/tables where xxxxxxxx is the name of your module (without spaces).
   * Modify any other variables defined in the constructor (see comment in the code skeleton for their meaning).
Test your descriptor
Launch Dolibarr and go to page Setup->module? You must see a new line with your new module and the possibility to activate it or not (browse all the tabs of each category of modules to find it). It's value of $this->special that determines in which tab will be your module.
Create your SQL tables and the PHP accessor class (optionnal)
Create your .sql file
by
Rules to follow:
  • Add the files about creating tables commands on the principle of a file llx_matable.sql per table with a possibly file llx_matable.key.sql (see existing files in mysql/tables for examples).
  • To manage data, you must create a file called data.sql inside directory /mymodule/sql/ that contains SQL command to add/edit/delete datas.
Test your .sql files
Once the files ready, you can return to Dolibarr to disable the module, dropper tables in database and reactivate the module. The tables should be recreated by the activation of the module. If this is not the case, check your scripts by passing them by hand, or check the Dolibarr logs.
Generate the accessors PHP class
Ajouter vos onglets sur les fiches entités (optionnel)
Quand: Pour ajouter un onglet sur une fiche entité (facture, commande, proposition commercial, adhérent...)
	// where entity can be
	// 'thirdparty'       to add a tab in third party view
	// 'intervention'     to add a tab in intervention view
	// 'supplier_order'   to add a tab in supplier order view
	// 'invoice'          to add a tab in customer invoice view
	// 'order'            to add a tab in customer order view
	// 'product'          to add a tab in product view
	// 'propal'           to add a tab in propal view
	// 'member'           to add a tab in fundation member view
Le tableau doit contenir une liste de chaine, chaque chaine représentant un nouvel onglet. Le format de la chaine étant composée de 4 parties séparées par ":"
  • Partie 1: Le code entité dans lequel doit apparaitre l'onglet qui est une valeur parmi celle-ci:
    • 'thirdparty'
    • 'intervention'
    • 'supplier_order'
    • 'supplier_invoice'
    • 'invoice'
    • 'order'
    • 'product'
    • 'propal'
    • 'member'
  • Partie 2: Le titre de l'onglet. Cela peut être un libellé en dur ou mieux un code traduction présent dans un fichier lang.
  • Partie 3: Le nom du fichier .lang qui contient la correspondance entre le code traduction et le libellé à afficher.
  • Partie 4: L'url de la page à afficher quand on clique sur l'onglet. La chaine __ID__ sera remplacée automatiquement par l'Id de l'entité concernée.
Créer une page écran PHP
Vous devez ensuite créer vos pages PHP qui se basent sur les données de vos tables en utilisant les squelettes fournis comme exemple dans le répertoire dev/skeletons (Pour le développement d'un script en ligne de commande, voir Developpement_script).
Y recopier le fichier skeletons_page.php qui va servir de point de départ à votre page ainsi que le fichier pre.inc.php. Modifier le fichier pre.inc.php afin que le chemin relatif du
soit correct, en fonction de la profondeur de répertoire dans laquelle se trouve le fichier pre.inc.php (Enlever ou supprimer des "../"). C'est dans le main qu'est chargé l'environnement technique ainsi que les habilitations. Les variables objets suivantes sont alors positionnées:
  • $db L'objet qui contient le handler de connexion ouvert à la base de donnée.
Accès à la base
Si vous avez besoin de réaliser des modifications en base dans votre propre table ajouté, utilisez la classe générée plus haut.
ou $db->rollback()  // Annule
Pour une lecture:
if ($resql)
	$num = $db->num_rows($resql);
	$i = 0;
	if ($num)
		while ($i < $num)
			if ($obj)
				// You can use here results
				print $obj->field1;
				print $obj->field2;
			$i++;
Définition du style
Par exemple:
$form=new Form($db);
print $form->select_date('','mykey',0,0,0,"myform");
$datefacture = dolibarr_mktime(12, 0 , 0, $_POST['mykeymonth'], $_POST['mykeyday'], $_POST['mykeyyear']);
print strftime('%A %d %B %Y', $datefacture);
Tester votre page
Aller sur la page Configuration->module, vous devez voir apparaitre un icone qui permet d'accéder à la page de configuratione tvous devez etre capable de modifier ces options et les voir conservé en base.
Définissez vos entrées
Pour cela, il vous faut définir dans le fichier descripteur de menu le tableau
$this->menu
Ce tableau contient toutes les entrées qui apparaitront dans les menus une fois le module activé. Les fichiers de descripteur de module exemple possède un exemple de déclaration de menu haut ainsi que de ces entrées menu gauche correspondantes.
Tester vos entrées menus
Désactiver et réactiver votre module sous Dolibarr, les entrées menus doivent alors apparaitre.
La définition des permissions que gèrera votre module se fait dans le fichier descripteur créé dans la première étape. Modifier la ligne $this->rights_class = 'facture' par
Ensuite remplissez le tableau $this->rights avec autant d'entrée que de permissions différentes à gérer.
$this->rights[$r][0] = 10001;
$this->rights[$r][3] = 1;
$r++;
Définissez vos box
Exemple:
Aller dans le menu Accueil - Configuration - Boite. Vos boxs doivent apparaitre dans la liste des box activables. Avticer les, aller sur la page d'accueil et vérifier qu'elles s'affichent correctement.
Définissez l'export
Tester votre export
Tester votre feuille de style
Assurez vous que votre module est actif. Appelez la page d'accueil de Dolibarr. Afficher la source de la page HTML. Vous devriez voir dans l'entête HTML, une ligne déclarant votre feuille de style.
Quand: Si vous voulez que des actions particulières s'exécutent suite au déclenchement d'action s standards de Dolibarr (exemple: je veux mettre à jour une table de mon module quand une facture se crée dans Dolibarr), il vous faut créer un fichier de triggers.
Voir aussi Interfaces_Dolibarr_vers_exterieur et Interfaces_Exterieur_vers_Dolibarr
  • Aller dans le répertoire /build et recopier le fichier makepack-dolibarrmodules.conf en makepack-monmodule.conf. Attention, ce répertoire peut ne pas être fourni dans les packages de versions stables. Si c'est le cas, il peut être récupéré dans le snapshot CVS disponible en téléchargement sur le site web Dolibarr dans la rubrique Version de développement (prendre dans ce cas tout le répertoire build qui est un répertoire autonome et indépendant de la version).
Le script vous demande le nom de votre module, sa version majeure et mineure. Un fichier monmodule.tgz va alors être fabriqué contenant votre module prêt pour être déployé.
tar -xvf monmodule.tgz
Quelques règles de codage
Utilisation du MDA
Une méthode pour générer un module fonctionnel depuis l'UML est en cours de mise au point. Plus d'informations sur la page Générer un module par MDA.
