Table llx events
Content/Contenu/Contenido
En verysmall.png Contains the triggers events
Fr verysmall.png Contient les évènements des triggers
Es verysmall.png Contiene los eventos de los triggers
Structure
rowid int(11)   PRI NULL auto_increment technical index
tms timestamp NO CURRENT_TIMESTAMP last update date
type varchar(32) NO type of event
entity int(11)   1 multi company id
dateevent datetime YES NULL date of event
fk_user int(11) YES NULL ID user (llx_user->rowid)
description varchar(250) NO full description of event
ip varchar(32) NO ip
fk_object int(11) YES NULL ID of object (any table_of_related_object->rowid)
