Table llx export model
Revision as of 08:15, 26 June 2009 by Simnandez (talk | contribs) (Created page with 'Category:Table SQL Category:ExportsEn Category:Exports Category:Exportaciones {{ListOfTables}} = Content/Contenu/Contenido = {{flag en}} Contains export models ...')
En verysmall.png Contains export models
Fr verysmall.png Contient des modèles d'exportation
Es verysmall.png Contiene los modelos de exportación
Structure
rowid int(11)   PRI NULL auto_increment technical index
fk_user int(11) NO 0 ID of user made the model (llx_user->rowid)
label varchar(50) NO label of model
type varchar(12) NO type of export
field text NO field to export with model
