Table llx ecm directories
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the directories of Electronic Content Management
Contient des directories du Gestion Electronique de Documents
Contiene los direcotorios de la Gestión Electrónica de Documentos
Structure
Field | Type | Null | Key | Default | Extra | Description |
rowid | int(11) | PRI | NULL | auto_increment | technical index | |
label | varchar(32) | NO | label of directory | |||
entity | int(11) | NO | 1 | multi company id | ||
fk_parent | int(11) | YES | NULL | parent | ||
description | varchar(255) | NO | description of directory | |||
cachenbofdoc | int(11) | NO | 0 | |||
date_c | datetime | YES | creation date | |||
date_m | timestamp | NO | CURRENT_TIMESTAMP | last update date | ||
fk_user_c | int(11) | YES | NULL | ID of creator user (llx_user->rowid) | ||
fk_user_m | int(11) | YES | NULL | ID of last modifier user (llx_user->rowid)
