Table llx commande fournisseurdet
Contenu
  Contient le détail des lignes de commandes fournisseurs.
  Contains the details of provider orders lines.
  Contiene los detalles de las líneas de los pedidos a proveedores.
Structure
rowid int(11)   PRI NULL auto_increment technical index
fk_commande int(11) YES NULL ID of order (llx commande->rowid)
fk_product int(11) YES NULL ID of product (llx_product->rowid)
ref varchar(50) YES NULL ref. of product
label varchar(255) YES NULL label of product
description text YES NULL product description
tva_tx double(6,3) YES NULL VAT taxes
qty double YES NULL Quantity of product
remise_percent double YES 0 discount percentage
remise double YES 0 discount amount
subprice double(24,8) YES 0.00 unit price before
total_ht double(24,8) YES 0.00 total excluding tax
total_tva double(24,8) YES 0.00 total tax
total_ttc double(24,8) YES 0.00 total with tax
product_type int(11) YES 0 type of product
date_start datetime YES NULL start date if service
date_end datetime YES NULL end date if service
info_bits int(11) YES 0 TVA NPR or not
