Table llx c propalst
Revision as of 13:43, 25 May 2009 by Simnandez (talk | contribs)
Content/Contenu/Contenido
En verysmall.png Contains different possible states of the of commercial proposals.
Fr verysmall.png Contient les différents états possibles des propositions commerciales.
Es verysmall.png Contiene los diferentes posibles estados de los presupuestos.
Structure
id int(11)   PRI NULL auto_increment technical index
code varchar(12) code of proposal state
libelle varchar(30) YES NULL label of proposal state
active tinyint(4) 1 is the proposal state active?
