Table llx c input method
Content/Contenu/Contenido
En verysmall.png Contains the different methods of purchasing from suppliers.
Fr verysmall.png Contient les différentes méthodes d'achat au fournisseurs.
Es verysmall.png Contiene los diferentes métodos de compra a proveedores.
Structure
rowid int(11)   PRI NULL auto_increment technical index
code varchar(30) code of method order
libelle varchar(60) YES NULL label of method order
active tinyint(4) 1 Is the method active?
